06-03-2013, 05:15 | #1 (permalink) |
Banned Join Date: May 2013
Member: 1933363 Status: Offline Thanks Meter: 6 | RM-237 (Nokia 3110c)SECURITY_TEST failed! Using device: HTI, FW ver: 00.50, SN: 0100F400 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 254001102DEB7C5693F9F217E5F452A6E2639509 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35683302377995 Original Product code: 0566963 Bluetooth ID: 0022FDF0A98A SIMLOCK PA identifier: [0] PA_SL Phone type: RM-237 (Nokia 3110c) SW version: V 07.01 21-08-08 RM-237 (c) Nokia. Imei plain: 35683302377995-6 Product code: 0514950 Battery voltage: 4865 mV, current: 96 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 356833023779956 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F help me |
06-03-2013, 05:24 | #2 (permalink) |
Freak Poster Join Date: Dec 2012 Location: india
Member: 1860703 Status: Offline Sonork: 100.1641707:shahid Thanks Meter: 35 | Repair simlock rpl & then sd repair write pm 1to 309 you will be sucess |
The Following User Says Thank You to shahid. For This Useful Post: |
06-03-2013, 05:43 | #3 (permalink) | |
Member: 1933363 Status: Offline Thanks Meter: 6 | Quote:
Repair simlock log Imei net: 356833023779956 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C087E4C4 Using device: HTI, FW ver: 00.50, SN: 0100F400 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData. PUBLIC ID: 254001102DEB7C5693F9F217E5F452A6E2639509 PRIVATE ID: 987B4F2BB3403A1F020B0B24FB872AFDD725056D Updating SIMLOCK ...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
06-03-2013, 07:00 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Looks like Hardware, BTW try to Recover Certificates, Go to Service Tab > IMEI & Security > IMEI Rebuilt > Click Recover Certificates, After that try again Repair SD & Repair SPLock must solve it, if not in Hardware, Else have to check for Hardware, specially for Physical Damage, Reflow full PCB & RAP IC, Post reply. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
06-03-2013, 16:03 | #5 (permalink) | |
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 254001102DEB7C5693F9F217E5F452A6E2639509 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Begin Certificate Request ... SERVER->MXKEY - BLADE X at host4, agent version 1.2 revision 0.5 Updating PRODUCTCODE (0566963)... OK Updating CMLA_KEY ...OK Updating WMDRM_PD ...OK MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C087E4C4 Using device: HTI, FW ver: 00.50, SN: 0100F400 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 254001102DEB7C5693F9F217E5F452A6E2639509 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NAND: Status reported bad blocks. | |
06-04-2013, 02:00 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - backup rpl: select RAP. - erase flash: get addr > select all, do not mark safe erase. - reflash with needed firmware version - Restore IMEI - Repair SpLock - Repair SD |
The Following User Says Thank You to gbluez For This Useful Post: |
