08-18-2011, 05:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | rm-356 nokia 5800 after flash simlock invalid..!! (SOLVED) before flash handset was dead. MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - maxkey Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0A2001182F208B527FC1041C0A3293D630F71536 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.24.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.24.0 revision: 2.0 size: 0x87D1A Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Processing MCU file: RM-356_21.0.025_prd.core.C00 [BB5,XSR 1.5] size: 92.20 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 4 min 24.031 s Processing PPM file: RM-356_21.0.025_prd.rofs2.V19 [BB5,XSR 1.5] size: 18.36 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Erase size: 44 MB CMT FLASH,MuxOneNAND area [06560000-0915FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 54.562 s Processing PPM file: RM-356_21.0.025_C03_prd.rofs3.fpsx [BB5,XSR 1.5] size: 711.08 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 2.172 s Processing CNT file: RM356_20.0.010_008_xxx_U01.uda.fpsx [BB5,XSR 1.5] size: 4.42 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Erase size: 88.75 MB CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... Prog.status for Asic CMT ... NAND: Success Programming completed in 14.282 s Total time for flashing process(boot+erase+write) was 5 min 43.422 s Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 35798803******** Product code: 0573797 Battery voltage: 4104 mV, current: 239 mA ApeCoreSw: V 21.0.025 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
08-18-2011, 05:42 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Do not want to tell you Age: 38
Member: 1538800 Status: Offline Sonork: Offline Thanks Meter: 18 | 1 A key recovery backup. go Service>IMEI & Security>IMEI rebuild>Restore Ime 2 No backup? RPL need to purchase new |
The Following User Says Thank You to haixiang For This Useful Post: |
08-18-2011, 05:43 | #3 (permalink) |
Member: 1538800 Status: Offline Sonork: Offline Thanks Meter: 18 | 1 A key recovery backup. go Service>IMEI & Security>IMEI rebuild>Restore Imei 2 No backup? RPL need to purchase new |
The Following 2 Users Say Thank You to haixiang For This Useful Post: |
08-18-2011, 05:53 | #4 (permalink) |
Freak Poster Join Date: Dec 2008 Location: kerala
Member: 914045 Status: Offline Thanks Meter: 51 | 1-back up rpl 2-full erace phone 3-flash with low version(v10.0.10 it shows pa sl2) 4-restore rpl 5-repair sl data using mx-key .. tested by me |
The Following 3 Users Say Thank You to smrithanev For This Useful Post: |
