Old 09-18-2012, 16:06   #1 (permalink)
Member: 1436625
Thanks Meter: 2
RM-436 (Nokia 7210 Supernova) any one hellp me plz.......
Phone type: RM-436 (Nokia 7210 Supernova)
SW version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35318003877632-7
Battery voltage: 4884 mV, current: 62 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: XXXXXX, ver:
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Old 09-18-2012, 19:06   #2 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
repair sd the udate sim lock then wrtie full pm and make full factory setting
Old 09-18-2012, 20:33   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Language Pack:
- not available.
SIMLOCK invalid!
Bro.
Go to:
- Service Tab > PM Tab > Click Super SD Auth then Click Repair SD
- Service Tab > IMEI & Security Tab > Simlock Tab > Tick Repair Simlock & Click Repair SPLock
- At the Last Reset All.
Job Done
BR,
ZUBER
Old 09-19-2012, 16:05   #4 (permalink)
Member: 1436625
Thanks Meter: 2
Originally Posted by .::ZUBER::. View Post
Bro.
Go to:
Job Done
BR,
ZUBER
now it coms to SECURITY_TEST faild
Old 09-19-2012, 17:47   #5 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Go to Service Tab>Click Load from File>go to address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-436.PM file, now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
Old 09-25-2012, 12:26   #6 (permalink)
Member: 1506694
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
Old 09-25-2012, 12:27   #7 (permalink)
Member: 1506694
nokia 7210 suprrnova CMT PAPUBKEYS is blank/erased.
Old 09-25-2012, 12:39   #8 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
What was Phone condition when came to you?
If IMEI blank from you, then Reflash again will solve it.
If came to you with IMEI blank,
Then return Phone to Customer, RPL Erase non affordable for this Cheap Phone.
BR,
ZUBER
Old 09-25-2012, 20:04   #9 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
1.untick fast and safe flash
2.do the full flash with highest version
3.write pm 1-309 field with pmm and sd auth
that's all
BR.
Arsalan gsm2000
Page generated in 0.20010 seconds with 9 queries
