12-11-2009, 17:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | RM-495 5130c-2 RESTORING RPL FAILED!!!! (ANSWERED) Firstly I take full back up of VERY GOOD "RPL&PM" and I flash the phone with same firmware (6.94) but it shows only NOKIA on screen- it did'nt turn off even with power off BUTTOM, so i take the battery out and again when i put the battery it shows "CONTACT SERVICE" logs here:: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35691903438067-6 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SO I FLASH THE PHONE WITH FIRMWARE WITH 7.91 (STILL CONTACT SERVICE) AFTER RESTORING VERY GOOD RPL(yes i'm sure fine rpl) CONTACT SERVICE IS GONE BUT SOMETHING ERROR IN THE LOGS::: RPL: "C:\mobileEx\3.3\data\backup\RPL\BB5_3569190343806 7_BACK.rpl" Imei: 35691903438067 Restoring RF/BB DATA from backup ... RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 02A0011039F08A56179BC408F7A26BB40DCFD258 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Erasing CMT NPC ... OK Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 02A0011039F08A56179BC408F7A26BB40DCFD258 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0577793)... OK Updating PSN (IBX248830)... OK Updating HWID (2000)... OK Updating SIMLOCK...OK Trying to update SUPERDONGLE_KEY ...error 0x0 Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35691903438067-6 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356919034380676 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FF AFTER RESTORING RPL ONLY SIMLOCK TEST PASSED!!!! I want to know that why only """simlock lock test passed""", but SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. PLZ HELP!!!!!! |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
12-11-2009, 17:47 | #2 (permalink) |
Freak Poster Join Date: May 2004 Location: Silent Mode Age: 39
Member: 65656 Status: Offline Thanks Meter: 91 | Code: Trying to update SUPERDONGLE_KEY ...error 0x0 problem is Code: This phone have PM308 protected, SD security in not restorable. but possible to repair , with other (531x) type "not protected sd_key" . all done if backup rpl&pm valid. try and prove , goodluck |
The Following 2 Users Say Thank You to neo_2005 For This Useful Post: |
12-11-2009, 17:54 | #3 (permalink) |
Freak Poster Join Date: Jun 2007 Location: lost world Age: 45
Member: 522783 Status: Offline Thanks Meter: 62 | bad simlock data and superdongle data in org pm308, this is sl3 phone with 308 protection,sd data cannot be restore. even mt or ub cant fixed it...so,just wait.... |
The Following User Says Thank You to rickliew For This Useful Post: |
12-11-2009, 18:10 | #4 (permalink) | ||
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
Plz help me how to know which is the exact pm for this phone. here is the most probable pm of this phone--http://rapidshare.com/files/319473678/temp.pm.html | ||
12-11-2009, 18:37 | #5 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Street line baby
Member: 695310 Status: Offline Thanks Meter: 144 | thats all accident bro...not your fault,or mx-key......before all that phone hank,n cntac servis damage 75% by user,populary from charging user ...pm damage at user charging....ask your user |
The Following User Says Thank You to adi sukmono For This Useful Post: |
12-12-2009, 04:59 | #6 (permalink) | |
Freak Poster Join Date: May 2009 Location: West Java Flasher
Member: 1035137 Status: Offline Thanks Meter: 72 | Quote:
better dont use this pm. next time better you read and save to PC manual. Service -> PM -> Read -> save to pc | |
The Following User Says Thank You to mr. uem For This Useful Post: |
02-03-2010, 15:45 | #7 (permalink) |
Freak Poster Join Date: Aug 2009 Location: India
Member: 1095362 Status: Offline Thanks Meter: 70 | 5130c-2 contact sevice Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 08100216FC157E5682BA7DACA4AE72BD1DDC277F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35417 Original Product code: 0577793 Bluetooth ID: 0025487B32D5 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35417 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35417 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF but my handset shows contact service on start up |
The Following User Says Thank You to khanraheem143 For This Useful Post: |
12-30-2010, 13:25 | #9 (permalink) |
Major Poster Join Date: Feb 2009
Member: 973337 Status: Offline Thanks Meter: 8 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 297001021EAD7D566279A287E9C33992B3027D73 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: Empty Original Product code: Empty NPC_DATA invalid ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 12345610654321-? Product Code: 0578115 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! I received this result when i check with BUS Check. How can i solve the NPC_DATA, SIM_LOCK, IMEI Problems. But, Mobile is switched on. I'm having full RPL Backup. But when i restore it, mobile going to dead. Please help me... |
The Following User Says Thank You to link2kannan For This Useful Post: |
12-30-2010, 14:05 | #10 (permalink) |
Member: 973337 Status: Offline Thanks Meter: 8 | When i click SCAN the following is abserved. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 12345610654321-? Product Code: 0578115 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! Please help me to solve this. I have backup of RPL. |
12-30-2010, 14:34 | #11 (permalink) | |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
Bro sl3 simlock data corrupted not done now. Wait nex mxkey update. (Best knowing Manole. when they give sl3 splock update then you can if your orginal imei not 1234.......) Last edited by Tarikul Islam; 12-30-2010 at 14:40. | |
The Following User Says Thank You to Tarikul Islam For This Useful Post: |
12-30-2010, 15:24 | #13 (permalink) |
Member: 973337 Status: Offline Thanks Meter: 8 | am having BB5_35417903240764_BACK.rpl for the phone, but its certificate are corrupted, so after write rpl to phone, the imei are getting corrected. but, the phone is not getting on. it simply stays blank white screen after nokia logo. |
12-30-2010, 15:56 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | After restoring RPL, just flash with LATEST FIRMWARE eg. 7.97. Everything will be OK. Try and post result. Br, Shadab Ahmad |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
NOKIA lock 2 provider list needed | ondenuove | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-15-2011 16:45 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
