11-21-2012, 12:08 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Quote:
and phone shows not charging when i pluged charger... MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C080CDEA Using device: HTI, FW ver: 00.50, SN: 01003BAD Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14213(16-10-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 21B0020A81DB03444BE6F101939F395A1D436050 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8 Original Imei: 35903904523280 Original Product code: 059F0N3 Bluetooth ID: B05CE5E3B54C SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone type: RM-745 (Nokia C5-00) SW version: V ICPR82_11w16.3.13 15-06-12 RM-745 (c) Nokia Imei plain: 35903904523280-3 Product code: 059F0N3 Battery voltage: 4434 mV, current: 119 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed "C:\Program Files\Nokia\Phoenix\Products\RM-745" folder created. Imei net: 359039045232803 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | |
