12-13-2010, 10:45 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 7260 cnt failed Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8826 [ST M58MWR128FU,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00860E45:2984DA60 ASIC type: 2 UEM Imei: 35433400635347 Flash Imei: 35433400635347 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35433400635347_BA CK.rpl" Processing MCU file: rm17__05.900 [DCT4,DCT4 ALGORITHM] size: 8.03 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8826 [ST M58MWR128FU,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00860E45:3B8ADA60 Area [01000000-0101FFFF] erased in 1.219 s Area [01020000-0181FFFF] erased in 1 min 17.203 s Area [01E60000-01FDFFFF] erased in 14.625 s Flash programming ... Programming completed in 1 min 1.407 s File Processed in 2 min 42.797 s Processing CNT file: rm17__05.90.image_india [DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.81 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8826 [ST M58MWR128FU,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00860E45:0BDFDA6A Area [01A40000-01E5FFFF] erased in 39.938 s Flash programming ... Programming completed in 14.109 s Content extract fail, continue anyway ... File Processed in 1 min 22.938 s Processing PPM file: rm17__05.90w [DCT4,DCT4 ALGORITHM] size: 1.47 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8826 [ST M58MWR128FU,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00860E45:2984DA60 Area [01820000-01A3FFFF] erased in 20.297 s Flash programming ... Programming completed in 11.407 s File Processed in 42.312 s Flashing completed in 5 min 18.375 s Phone not responding ! some one said must use cnt128k where can i get, or any other solution plz kindly help me |
12-13-2010, 11:08 | #2 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1466124 Status: Offline Thanks Meter: 116 | Quote:
12-14-2010, 20:28 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | full erase by get address, untick safe erase. reflash. if all done and phone powered up, proceed to write pm and ini simlock. if still dead, check for hardware, most case bad flash chip. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
3330 v 412 fail with dfs 211 | denn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-19-2001 22:06 |
In wintesla 3310, what does cobba parrarel failed means | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-18-2001 16:05 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
