09-18-2011, 08:20 | #3 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Majuro, Marshall Islands
Member: 965137 Status: Offline Thanks Meter: 30 | The latest maybe.... I have here 501.21 which I believe the latest. Thing here is on the MCU, it is showing RM437 and not RM449. I'll check above and see... thanks.... |
09-18-2011, 08:43 | #5 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | UPDATE: Everything went thru as instructed but now i'm getting Security test failed...,, LOG: MXKEY Serial: [FT SCR2000 0] - C0850AA5 Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 20B00015C77D0052087F310502525807A8827B25 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.32.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.32.0 revision: 2.0 size: 0x83902 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35683802093370 Original Product code: 0577062 Bluetooth ID: 0023B4D7CC02 WLAN ID: 0023B4E70E42 SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-449 (Nokia E63) SW version: V ICPR71_09w47.8 05-08-10 RM-449 (c) Nokia Imei plain: 35683802093370-4 Product code: 0577062 Battery voltage: 4955 mV, current: 76 mA ApeCoreSw: 501.21.001 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356838020933704 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
09-18-2011, 08:47 | #6 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | I already have those. The MCU above is RM-437 and not RM-449, I want 449 if avail. Or should I flash entire RM-437 firmware, then load up RM-449 pm? Last edited by LuverBoy; 09-18-2011 at 08:53. |
The Following User Says Thank You to LuverBoy For This Useful Post: |
09-18-2011, 08:48 | #7 (permalink) |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Do this with mxkey Just Tick rf bb press pmm auth and write pm 1 to 309. - do not load any pm - mark : load rff bb from server - do PMM Auth - click write after auth is successful. |
09-18-2011, 09:15 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | Mate, there's no problem with your MCU. RM-449 using MCU and PPM from RM-443. Here is a litle quote from RM449_0568946_510.21.010_001.vpl file : Quote:
09-18-2011, 09:50 | #9 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | Ok, just followed your simple guide above and flash went well, no security or dongle errors. When switching the phone to Normal Mode, white screen. Pulled fbus and put in battery, same thing, white screen..... Am I missing something here? |
09-18-2011, 11:55 | #12 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | MXKEY Serial: [FT SCR2000 0] - C0850AA5 Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 20B00015C77D0052087F310502525807A8827B25 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.32.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.32.0 revision: 2.0 size: 0x83902 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35683802093370 Original Product code: 0577062 Bluetooth ID: 0023B4D7CC02 WLAN ID: 0023B4E70E42 SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-449 (Nokia E63) SW version: V ICPR71_09w47.8 05-08-10 RM-449 (c) Nokia Imei plain: 35683802093370-4 Product code: 0577062 Battery voltage: 4960 mV, current: 91 mA ApeCoreSw: 501.21.001 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Still get pop up error - Access violation at address......... |
09-20-2011, 00:02 | #15 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | I already have the latest firmware. 501.21.001 RM-449. I got rid of the access violation error by flashing pm. Decided to downgrade to 437 which went alright no errors (didn't save log either). Next, I flashed 449 pm then, flash the whole 449 firmware. Still white screen. I can hear the keys when press, vibrates when it powers up and still white screen. Could it be hardware? |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
