05-12-2009, 10:39 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 656877 Status: Offline Thanks Meter: 4 | rpl writing on mx ok hone Type: RM-166 (Nokia 6070) SW Version: V 03.20 18-05-06 RM-166 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 35939600702272 Product Code: 0530234 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: S Language Pack: English,Chinese S,Malaysian "C:\Program Files\Nokia\Phoenix\Products\RM-166" folder created. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Counter: 0/3, 0/10 CONFIG_DATA: 769C586AE3D660FC PROFILE_BITS: C767441E80B285A0 SIMLOCK_DATA corrupted! ASIC ID: 0x2142 [UPP8M_v5.0] u_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0044478F:2984DA60 ASIC type: 2 UEM Imei: 35939600702272 Connecting to server ...OK, Login ... Hello C08005C5, you have 990 credits left. RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35939600702272.RP L" ASIC ID: 0x2142 [UPP8M_v5.0] u_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Programming FLASH Imei ... FLASH programmed successfully. Imei net: 35939600702272 Counter: 0/3, 0/10 CONFIG_DATA: 2C4470EAE2A307B1 PROFILE_BITS: 7DFC00B427B57FF1 SIMLOCK_DATA corrupted! Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35939600702272 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Phone Type: RM-166 (Nokia 6070) SW Version: V 03.20 18-05-06 RM-166 (c) Nokia. Imei plain: 35939600702272-5 Imei OTP: 35939600702272 Product Code: 0530234 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: S Language Pack: English,Chinese S,Malaysian Imei net: 35939600702272 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OP |
The Following 2 Users Say Thank You to hamra_ksa For This Useful Post: |
how to calculate RPL for free on MX-key | twisted07 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-25-2010 15:09 |
BB5 RPL on MX-KEY | saeedullah_khan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-21-2009 12:17 |
1200-1208 rpl write problem by mx key | dreams_bd | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-05-2009 18:34 |
