View Poll Results: SD repair Is working or not
Yes It Worked!!! 105 28.23%
Not It Doesn't Work @ All 112 30.11%
It Worked Somehow on Some Phones 83 22.31%
No Its a Fake Update 72 19.35%
Voters: 372. You may not vote on this poll
Old 02-04-2010, 15:31   #16 (permalink)
Member: 1217701
Thanks Meter: 9
Arrow
Originally Posted by van View Post
i tried on 5220 security test failed...same problem
UR Solution Here
SECURITY_TEST failed - Read how to solve here
Old 02-04-2010, 15:33   #17 (permalink)
amralkareem's Avatar
Member: 153397
Sonork: 113032
Thanks Meter: 360
Old 02-04-2010, 15:40   #18 (permalink)
gsm4soltan2's Avatar
Member: 317614
Sonork: 100.1575662
Thanks Meter: 117
work but security test failed
Old 02-04-2010, 15:42   #19 (permalink)
Member: 169447
Thanks Meter: 4
work for me,but not perfect
5800=ok
5220=security failed and i use mt box=is ok
7210s=security failed
mx team,please fix bugs
Old 02-04-2010, 15:44   #20 (permalink)
Zegarek's Avatar
Member: 551345
Sonork: 100.1590161
Thanks Meter: 318
ITS FAKE UPDATE tested for 5 phones not works !!!
Old 02-04-2010, 16:29   #21 (permalink)
Member: 1227568
I also tried to not do
Old 02-04-2010, 16:29   #22 (permalink)
ZubairArain's Avatar
Member: 751908
Thanks Meter: 186
Fake.......Fake.....for me
5130c on security_test failed!...................
~ZubairArain~
Old 02-04-2010, 16:30   #23 (permalink)
sufianto_0202's Avatar
Member: 169781
Thanks Meter: 14
I think this mxkey must fix this update.I tried 3 pcs 5220 ( with manole method ) always security failed.pls fix this bugs.
Old 02-04-2010, 16:33   #24 (permalink)
Member: 445578
Thanks Meter: 440
Exclamation
Originally Posted by akt007 View Post
1000% fake update
for me not working,6 phones = 6x security test failed
do you know the procedure how to do for problem security test failed & sd repaire
1st try to learn the procedure!!!!!!
Old 02-04-2010, 16:37   #25 (permalink)
Member: 445578
Thanks Meter: 440
Exclamation
Originally Posted by noey View Post
100 phones = 100 x security test failed = 100 X SIMLOCK failed
you can do both problem solve by mx-key! 1st try to get help from other user or supporter then post here that fake or good!
Old 02-04-2010, 16:39   #26 (permalink)
Member: 445578
Thanks Meter: 440
Exclamation
~ZubairArain~
write pm with sx4 auth with ticked block 1 &309 then will be ok
Old 02-04-2010, 17:23   #27 (permalink)
Member: 762819
Thanks Meter: 232
No No dears! Don't try to push the reality. SD repair is not working, not even on 1 phone has worked. We humbly request Manole and Alim to fix it immedailtey as we can repair the damaged phones by mx key. Thanks
Old 02-04-2010, 17:37   #28 (permalink)
Member: 234854
Thanks Meter: 30
for me it works,cos i did 1 5220 today and everything was ok.
Old 02-04-2010, 18:26   #29 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
after sd repairing,new problem comes,security test failed,
Old 02-04-2010, 18:31   #30 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,435
10 phone like e71,e66,6300,6500,6680,..... test repair sd is ok but security_test failed...........but solve very easy........no problem
6680 only write 1,309 and ok
e71 4 pcs after repair SD for repair sc fail only push repair sim_lock with make rpl and solve sc failed
5800 very hardly but solve ......reset npc and write full pm and edit backup rpl,only npc write,witout rf/bb etc.....and make repair sim_lock
anyway sd_repair work but litlle hard work.....
The Following User Says Thank You to BABAK NURI For This Useful Post:
3110c sd repair successfully with mx-key JINDALGSM™ MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-04-2010 08:11
SD Repair Sucess With Mx key naveen_mobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-12-2010 14:29
n72 SD Repair l For MX-Key 100% working akt007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-06-2010 11:48
3110c SD Repair l For MX-Key 100% working mdmosheur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 11:46
Any sd repair option in mx key like ub shivram MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-11-2009 07:57
Page generated in 0.46520 seconds with 9 queries
