05-01-2010, 07:06 | #1 (permalink) |
Crazy Poster Join Date: Apr 2010 Location: Pakistan
Member: 1292027 Status: Offline Sonork: 1591775 Thanks Meter: 73 | Seccessfully flash nokia 7610 selact fast phone Library version: 1.0.0.8069(22-04-2010), 1.0.0.12843(27-04-2010) ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00086191:2984DA7E ASIC type: 5 UEM Imei: 35955501089802 Flash Imei: 35955501089802 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35955501089802_BA CK.rpl" Processing file: RH51_52_67_68PE706420.C1 as MCU [WD2 BT2,WD2 ALGORITHM] size: 24.51 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0400 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00086191:2984DA7E Area [00000000-0000FFFF] erased in 0.531 s Area [00010000-00FFFFFF] erased in 2 min 4.234 s Area [02000000-0287FFFF] erased in 1 min 6.219 s Area [02FC0000-02FEFFFF] erased in 1.469 s Flash programming ... Programming completed in 7 min 33.812 s File Processed in 11 min 7.282 s Processing file: RH51PE706420.03 as PPM [WD2 BT2,WD2 ALGORITHM] size: 2.73 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00086191:2984DA7E Area [00000000-0000FFFF] erased in 0.547 s Area [02A00000-02CAFFFF] erased in 21.046 s Flash programming ... Programming completed in 43.469 s File Processed in 1 min 24.235 s Flashing completed in 13 min 16.094 s Phone Type: RH-51 (Nokia 7610) SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia. Imei plain: 35955501089802-1 Product Code: 0514537 Cellular System: GSM ASIC ID: 0x1081, type: 5 Language Pack: - not available. Imei net: 35955501089802 Version: SIMLOCKLIB VERSION 2.29 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000005 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 13 min 41.062 s |
The Following User Says Thank You to Nazain janu For This Useful Post: |
