02-12-2012, 11:33 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | security test failed need help SW version: V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia Imei plain: 35\\\\\\\\\\\\\\\\\\ Product code: 0590825 Battery voltage: 4323 mV, current: 0 mA ApeCoreSw: V 11.0.054 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35\\\\\\\\\\\\\\\\\ Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
02-12-2012, 14:13 | #2 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Bangladesh
Member: 671937 Status: Offline Sonork: 100.1613181 Thanks Meter: 94 | Quote:
1. repair sd 2. supersd auth 3. write pm. 1 & 309 think ur problem will be solve..........if not solve contact me on yahoo ill try to solve via teamviewer........... THANKS & BR | |
02-12-2012, 14:27 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | I tell you very simple and 100000000000%%%%% tested solution.. 1. Press Repair SD. When ask to write RFBB press No....... 2. Load Pm file and select only 1, 309.... and press write... Its for security test fail...... solution... |
02-12-2012, 19:16 | #6 (permalink) |
Registered User Join Date: Sep 2005 Location: (earth°) Age: 46
Member: 181110 Status: Offline Sonork: 1001648353 Thanks Meter: 180 | try this tested more then 12 time 100/100 work http://forum.gsmhosting.com/vbb/8144086-post10.html |
02-13-2012, 09:46 | #8 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Quezon City, Philippines
Member: 556408 Status: Offline Thanks Meter: 12 | Quote:
1. back up rpl 2. get pm 1 ,309 3 super sd auth 4 write pm 5 flash back the rpl then unlock it again... hope this will help | |
The Following User Says Thank You to sily14344 For This Useful Post: |
02-14-2012, 10:29 | #13 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | i suggest u to post the writing pm 1 & 309 log here, so people here will see if u do it correctly, cause u just said same, same, and same and try SEARCH button for more solutions. br |
02-14-2012, 10:34 | #14 (permalink) | |
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. Warning: failed to write 1 - 34 (80 bytes) Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 1.95 " contract " try via teamviwer also but Last edited by praji; 02-14-2012 at 10:41. | |
02-14-2012, 10:37 | #15 (permalink) | |
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
Warning: failed to write 1 - 34 (80 bytes) br | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
