02-09-2010, 09:28 | #1 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1173492 Status: Offline Thanks Meter: 27 | SECURITY_TEST failed problem solve tested Complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. BR parwez |
02-09-2010, 09:30 | #2 (permalink) |
Member: 1173492 Status: Offline Thanks Meter: 27 | SW Version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35366201503310-3 Product Code: 0563611 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353662015033103 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
6120 after repair sd security test failed problem solved... | rickliew | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 04-08-2010 09:25 |
security test failed problem solved | nijascm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-27-2010 11:12 |
3120c SECURITY_TEST failed! NOT solved by MX KEY[SOLVED] | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-11-2010 07:33 |
Init Local Mode Failed - Problem Solved | SkyNet4u | HWK | 0 | 10-11-2008 13:40 |
