02-05-2010, 14:27 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | SECURITY_TEST failed solution i am tasted SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 355728 Product Code: 0514959 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-08-27T19:08:54Z SW Version: 07.01 Variant Version: 013 ProductProfile: RM237_0514959_07.01_013.spr Simlock: 0514959_simlock.bin Imei net: 355728 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF click repair sd then save see ur ur mobileEx folder C:\mobileEx\3.3\data\backup BB5_RM-411_35684002121....._SD.rpl this sd rpl u write mt-box.then u make sx4 pic download |
The Following 4 Users Say Thank You to gopalhot For This Useful Post: |
02-05-2010, 15:13 | #5 (permalink) |
Banned Join Date: May 2008
Member: 783336 Status: Offline Thanks Meter: 21 | today i am just try to solve sECURITY_TEST failed but no luck... after 1 trick...... work....... i use rpl pm and use sx4... after that i writ rpl pm... .. i was not sure that my set is ok, but when i see in detail its sECURITY_TEST pass........ so try again and again,... |
02-06-2010, 06:02 | #7 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | here's my logs after i've tried to repair my 7210c now goes to 12345 i can't write the orig rpl due to error 1ST BOOT : C0,07 [Rm-436] [2.0.9.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 09F00101CD8D7D561E5D6E117B45317CC39B870E RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : 7210c_Erase_64MB_kashi4gul CMT NOR Erase Area: 0x00000000-03FFFFFF CMT FLASH ERASE OK, Time: 05:58 CMT FLASH WRITE No Data Flashing Completed, Rebooting Mobile 1ST BOOT : C0,07 [Rm-436] [2.0.9.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 09F00101CD8D7D561E5D6E117B45317CC39B870E RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm436__05.20.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x00140000-0119FFFF CMT NOR Erase Area: 0x011A0000-0133FFFF CMT FLASH ERASE OK, Time: 00:04 Written: 8 Certificate(s) CMT FLASH WRITE OK, Time: 02:05 Chip SECTOR_SIZE: 128k Warning, Must be Used 128Kb Sector_Size CNT File CONVERSION: Already 128K Paged Source IMAGE : rm436__05.20.image_a CMT NOR Erase Area: 0x01BE0000-01F7FFFF CMT NOR Erase Area: 0x01F80000-03FBFFFF CNT FLASH ERASE OK, Time: 00:08 CNT FLASH WRITE OK, Time: 02:28 IMAGE : rm436__05.20.ppm_a CMT NOR Erase Area: 0x01340000-01BDFFFF PPM FLASH ERASE OK, Time: 00:02 PPM FLASH WRITE OK, Time: 00:48 Flashing Completed, Rebooting Mobile Using device: UFS_USB V2.7 (c) SarasSoft 2005. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 09F00101CD8D7D561E5D6E117B45317CC39B870E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: Empty Original Product code: Empty Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 05.20 15-10-08 RM-436 (c) Nokia Imei plain: 12345610654321-? Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 09F00101CD8D7D561E5D6E117B45317CC39B870E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 NPC verified Ok. Updating CMT CCC ...WriteDevice failed: Failed to read/write device failed, Result: 0000000000000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 09F00101CD8D7D561E5D6E117B45317CC39B870E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 NPC verified Ok. Updating CMT CCC ...WriteDevice failed: Failed to read/write device failed, Result: 0000000000000000 Certificate programmed successfully ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 05.20 15-10-08 RM-436 (c) Nokia Imei plain: 12345610654321-? Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! RPL: "C:\mobileEx\3.3\data\backup\BB5_35318003400----_BACK.rpl" Imei: 3531800340---- Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 09F00101CD8D7D561E5D6E117B45317CC39B870E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 NPC verified Ok. Updating CMT NPC ...WriteDevice failed: Failed to read/write device failed, Result: 0000000000000000 Certificate programmed successfully ! |
02-06-2010, 07:36 | #8 (permalink) |
Freak Poster Join Date: May 2009 Location: venezuela Age: 32
Member: 1027249 Status: Offline Thanks Meter: 24 | from here the solution: http://www.4shared.com/file/21413203...st_failed.html is a video tutorial created by me tested in 5220 from here RPL: http://www.4shared.com/file/21598259..._failed_V.html |
02-06-2010, 10:29 | #9 (permalink) |
Freak Poster Join Date: Sep 2008 Location: delhi
Member: 857876 Status: Offline Sonork: cellexpert-33 Thanks Meter: 63 | use mx-key 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model |
06-05-2010, 12:26 | #10 (permalink) |
Junior Member Join Date: Aug 2004 Age: 51
Member: 79177 Status: Offline Thanks Meter: 8 | Imei plain is invalid !!! Imei: 35930902998053 Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 12700214703B7E56A6DF9BBDE4120D8FFF709563 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Updating CMT NPC ...failed, Result: 0000000000000000 Certificate programmed successfully ! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0566963 Language Pack: - not available. Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Updating CMT NPC ...failed, Result: 0000000000000000 so plz any solu......thx for adv....................................... |
to manole n96 SECURITY_TEST failed!" no any Solution | zakryia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-06-2010 12:17 |
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 11:36 |
SECURITY_TEST failed! solution tested | mscomp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-05-2010 14:03 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! | Raven21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-27-2010 08:15 |
