Old 02-05-2010, 10:01   #1 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
Wink SECURITY_TEST failed! solved by MX KEY
There are steps for here u can see that
1) Bus check
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 3568330********
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 356833028678153
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
2) save backup of ORg RPL like this
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2760000F4F2E7D56AF5E8323C23795C45BA35E13
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35683302867815
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA is empty.
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
RPL saved to "D:\3110 akash\BB5_356833********_BACK.rpl"
3) Erase full flaSH wit erase file like this
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total erase size: 31.81 MB
CMT NOR area [00000000-01FCFFFF] erased in 2 min 59.297 s
CMT NOR area [00000000-01FCFFFF] erased in 7.375 s
4)flash phone (CMT, APE, ...)
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
RAP PAPUBKEYS is blank/erased.
Storing certificate ...OK
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-0031FFFF]
CMT NOR area [00320000-0105FFFF]
CMT NOR area [01060000-01067FFF]
CMT NOR area [01068000-0107FFFF]
erased in 3.859 s
Flash programming ...
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Programming completed in 2 min 9.219 s
Processing file: rm237__07.21.ppm_mr as PPM
[BB5,BB5 ALGORITHM] size: 3.55 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total erase size: 4.62 MB
CMT NOR area [01080000-0151FFFF]
erased in 1.109 s
Programming completed in 33.438 s
file rm237__07.21_sd_allmost_empty_512.fpsimage is empty, skipped.
Processing file: rm237__07.21.image_mr as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.00 MB
NOR page size in the phone is 128 K.
Formating FS: FILE2 ...
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Total erase size: 10.75 MB
CMT NOR area [01520000-01FDFFFF]
erased in 12.843 s
Converting UCP blocks to 128 K.
Programming completed in 35.828 s
Flashing completed in 4 min 28.266 s
Imei plain: 12345610654321-?
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei plain is invalid !!!
Imei net: 12345610654321?
Counter: 0/3, 0/10
Total time to process is 4 min 51.016 s
5) write cloned or edited RPl to the fone
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0514950)... OK
Updating PSN (7F0821634)... OK
Updating HWID (2000)... OK
Updating LOCK ...OK
Updating WMDRM_PD...OK
Certificate programmed successfully !
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
6) then wite org Rpl to the fone
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 3568330********
Counter: 0/3, 0/10
Br,
Akashub
The Following 6 Users Say Thank You to akashub For This Useful Post:
Old 02-05-2010, 10:44   #2 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
do all but same not work.
Old 02-05-2010, 10:45   #3 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
1) Bus check
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA is empty.
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
erased in 3.859 s
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
erased in 1.109 s
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
erased in 12.843 s
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Updating RF ...OK
Updating BB ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Updating LOCK ...OK
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Br,
Akashub
please upload clone rpl here
Old 02-05-2010, 10:51   #4 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
Wink repair
u can contact on me on yahoo
Old 02-05-2010, 10:54   #5 (permalink)
Crazy Poster
Member: 1226388
Sonork: jk khan
Thanks Meter: 13
I think you should have tried to write pm field 1and 309 with sx4.
There is no need of doing these steps for security test failed.
Old 02-05-2010, 10:56   #6 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
repair
its not only colned its edited u can download from here
Old 02-05-2010, 10:56   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,303
Brother Do After Superdongle Repaier ( security Test fail )
Then Post Log Here ...
Old 02-05-2010, 10:57   #8 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
Wink repair
k then u try with pm field 1and 309 with sx4. if not sucsses u can use this steps as MANOLE said,,,
Br,
akashub
Old 02-05-2010, 10:58   #9 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
Thumbs up repair
see my first post bro, it abt security Test fail
Old 02-05-2010, 11:07   #10 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Error
The file could not be found. Please check the download link.
Old 02-05-2010, 11:10   #11 (permalink)
Member: 715596
Thanks Meter: 244
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35684002153244-4
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
Old 02-05-2010, 11:12   #12 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,441
he he he he not solved his problem see here
http://forum.gsmhosting.com/vbb/show...26#post5374026
The Following User Says Thank You to sneha For This Useful Post:
Old 02-05-2010, 11:12   #13 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
yes if u have 5220 colend rpl plz uplaod
Old 02-05-2010, 11:13   #14 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
link not working send another link
Old 02-05-2010, 11:14   #15 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,043
impossible ..nothing new in that,...alredy npc corrupt while upload rpl fileof sd ,...not possible
The Following User Says Thank You to akhil_bbsr For This Useful Post:
6300 contact service solve by MX-KEY dessertcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 09-02-2010 17:35
7210c & 3110c contact service solved by mx key banti097 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-22-2010 12:58
3120c SECURITY_TEST failed! solved by MX KEY akashub Nokia Base Band 5 ( BB-5 ) 3 02-11-2010 10:31
3120c SECURITY_TEST failed! NOT solved by MX KEY[SOLVED] akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-11-2010 07:33
e71 after flash blank screen solved by mx key adaki_vishal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-10-2009 17:09
Page generated in 0.57152 seconds with 8 queries
