Old 12-04-2012, 04:11   #1 (permalink)
Member: 200541
sign application error MXkey - Help please
i have problem with my hti box. it juz happen on 3 dec, recently.
before, it has no problem at all.
i tried to click on "sign application" it nothing happen...
im now out of idea.. plz help...
thanks alot anyway
here is the link of picture
http://www.freeimagehosting.net/r1h8x
sorry, i tried upload the picture so it can show here but it couldn't.
thanks for the help.
Old 12-04-2012, 04:23   #2 (permalink)
Member: 1174311
Thanks Meter: 6
Plese sir try to install your HTI with other pc and update your box with the sign application if succes copy your "mobileEx.xml" from folder C:\mobileEx\3.5
and paste with the computer you want to use (C:\mobileEx\3.5)
Old 12-04-2012, 04:53   #3 (permalink)
Member: 172261
Thanks Meter: 364
timestamp expired
check your computer date! is it 04-Dec-2012
Old 12-04-2012, 05:13   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Install latest version of mobileEx WITHOUT ANY MODIFICATION!
You are using CROSSED MODULE, obsolete prohibited way and very buggy.
Old 12-04-2012, 05:18   #5 (permalink)
atif ikram's Avatar
Member: 1644460
Thanks Meter: 44
Check you mx box in this list , may be you are black listed
http://forum.gsmhosting.com/vbb/f550...9/#post8973132
The Following User Says Thank You to atif ikram For This Useful Post:
Old 12-04-2012, 09:00   #6 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
thanks alot anyway
r1h8x.jpg at Free Image Hosting
Hi,
Check Time & Date of your PC,
Unistall Mxkey Application & Delete MobileEx Folder manually,
Reinstall Mxkey Application & Sign Application, (Internet is must to sign)
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 12-07-2012, 10:03   #7 (permalink)
Member: 200541
ok thanks... i'll try n will update later
Old 12-10-2012, 09:27   #8 (permalink)
Member: 200541
thanks all the suggestion.
problem solved today.
uninstalled all the mxkey program and deleted all the folders
restart my comp, reinstalled and there sign application works perfectly.tq...
Old 12-10-2012, 19:39   #9 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
We Happy Solved Your Problem..
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 02-12-2017, 08:00   #10 (permalink)
Crazy Poster
Member: 1800651
Thanks Meter: 20
need mxkey update setup file, or only mobileEx (xml document) file.
thnx in advance...
Old 02-15-2017, 02:16   #11 (permalink)
Member: 1336065
Sonork: nao tenho
Error box mxkey only have pendrive mxkey hti with defect mias is working normal at the time of update box this giving error some tip ???
Page generated in 0.21828 seconds with 8 queries
