05-04-2010, 13:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | Siemens A65 Successfully unlock With Mx Key Need Test Point or cut 4 unlocking press "Recalc Allkey" and phone unlock Press POWER button shortly ! BOOTKEY: FC9236C818F9E6F9BC8DB13F74EFF06B Sending PapameterBoot: Ok. Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! BOOTKEY: FC9236C818F9E6F9BC8DB13F74EFF06B Sending PapameterBoot: No Bcore (TP open)! Press POWER button shortly ! Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. Device 921600 BAUD: Ok. SIEMENS A65 lg98 Sw10 SW FlashID: 0001 2212 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Start EEPROM segments at addres 0x7C0000 FSN: 28510ED6 -> PhoneID: D60E5128 OTP IMEI: 354497001110667 HASH: 8E92116E713DBC5148D617436BD78A7A Use OTP IMEI: 354497001110667 Using SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... BCORE backup in "C:\mobileEx\3.2\modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\A65lg98Sw10_BCORE_090504143133.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0x7C0000 size: 0x030000... EEPROM backup in "C:\mobileEx\3.2\modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\A65lg98Sw10_EEPROM_090504143138.bin" file. Write EEPROM addr: 0x7C0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Tested If u like my post press thank button Last edited by sahil00150; 05-04-2010 at 13:38. |
The Following 3 Users Say Thank You to sahil00150 For This Useful Post: |
12-13-2010, 13:28 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | SIEM module version: 1.01 B SIEM module ready. Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 230 (A65) A65 lg1 Sw15 23.03.05 14:06:51 IMEI: 354496xxxxxxxxx DisplayID: 37, Philips Epson S1D15G14 Code(05): OTP closed Code(0A): BOOTKEY misses in EEPROM Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3959 mV. SecurityMode: Customer Read Keys... SecurityMode: Customer Work only in FactoryMode! Use Skey! Read Info... SecurityMode: Customer Work only in FactoryMode! Use Skey! Read Keys... SecurityMode: Customer Work only in FactoryMode! Use Skey! Read and edit block 5005... HWID: 230 (A65) Date: 08/09/05 Variant: E 153 Std-Map/SW: 1/15 D-Map/Prov.: 12/135 The editing of the block 5005 is cancelled. Get Info... HWID: 230 (A65) A65 lg1 Sw15 23.03.05 14:06:51 IMEI: 354496xxxxxxxxx DisplayID: 37, Philips Epson S1D15G14 Code(05): OTP closed Code(0A): BOOTKEY misses in EEPROM Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3960 mV. SecurityMode: Customer DSP Firmware Version 09, Power Asic Project ID: 09, RF Chipset ID: 08 EELITE Info: free buffer 52630 bytes, free at all 54620 bytes, free for deleted 54620 bytes. EEFULL Info: free buffer 48858 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Battery Ri measurement: CutOff Idle: 3473mV, CutOff Talk: 3603mV, CutOff Idle: 3390mV, CutOff Talk: 3565mV, CutOff Idle: 3415mV, CutOff Talk: 3535mV, CutOff Idle: 3415mV, CutOff Talk: 3535mV. Operating time: Total 40220166 sec, Current SW 40220166 sec. Talk time: Total 523626 sec, Current SW 523626 sec. CSD: Total 17223 bytes, Current SW 17223 bytes. GPRS: Total 35819 bytes, Current SW 35819 bytes. Press POWER button shortly ! Phone off! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A70)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(AX75)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(CF62)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(SX1)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 230 (A65) A65 lg1 Sw15 23.03.05 14:06:51 IMEI: 354496xxxxxxxxx DisplayID: 37, Philips Epson S1D15G14 Code(05): OTP closed Code(0A): BOOTKEY misses in EEPROM Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3930 mV. SecurityMode: Customer Press POWER button shortly ! Phone off! Loading BootsModel(A65)... StartBoot does not loded! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not loded! Press POWER button shortly ! BOOTKEY: 6E75747A6F6973746865626573740000 Sending PapameterBoot: Ok. Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! BOOTKEY: 6E75747A6F6973746865626573740000 Sending PapameterBoot: Ok. Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A70)... StartBoot does not answer! Press POWER button shortly ! Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A65 lg1 Sw15 SW FlashID: 0089 8856 FlashID: 0089/8856 Flash Size: 16Mb Region(1): Blocks 255, Size 64Kb Region(2): Blocks 8, Size 8Kb Start EEPROM segments at addres 0x7C0000 FSN: 06B88003 -> PhoneID: 0380B806 OTP IMEI: 354496xxxxxxxxx HASH: 29C7F4B52F9B500DB6394AC809DC8164 Use OTP IMEI: 354496xxxxxxxxx Using SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... BCORE backup in "C:\mobileEx\3.4\modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\A65lg1Sw15_BCORE_101213132610.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0x7C0000 size: 0x030000... EEPROM backup in "C:\mobileEx\3.4\modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\A65lg1Sw15_EEPROM_101213132657.bin" file. Write EEPROM addr: 0x7C0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. |
The Following User Says Thank You to MOURAD™ For This Useful Post: |
12-25-2010, 08:10 | #3 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi pakistan Age: 41
Member: 388647 Status: Offline Sonork: sheerazi Thanks Meter: 161 | siemens MC60 successfully unlock by MXkey Press POWER button shortly ! HWID: 132 (MC60) Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 132 (MC60) MC60 lg95 Sw07 13.10.03 20:21:47 IMEI: 351954009401772 DisplayID: 34, Sharp Hynix HM17CM4101 Code(05): OTP closed Code(08): BOOTKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage very low! 3697 mV! SecurityMode: Customer Send SKey(45319575)... Phone Off. SKey Send: Ok! All Open. Press POWER button shortly ! Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. MobileMode: Service HWID: 132 (MC60) MC60 lg95 Sw07 13.10.03 20:21:47 IMEI: 351954009401772 DisplayID: 34, Sharp Hynix HM17CM4101 FSN: 801DBA9D SW FlashID: 0001 2212 Code(05): OTP closed Code(09): BOOTKEY is written in EEPROM Code(0D): Keys are registered in BCORE Code(13): Complete access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage very low! 3662 mV! SecurityMode: Factory Simulate Chip Card - Ok! Press POWER button shortly ! Phone off! Loading BootsModel(MC60)... Sending StartBoot Ok. Sending MainBoot Ok. Device 921600 BAUD: Ok. SIEMENS MC60 lg95 Sw07 SW FlashID: 0001 2212 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: 801DBA9D -> PhoneID: 9DBA1D80 OTP IMEI: 351954009401772 HASH: 26E01A6F0723912055B42781817B7C48 Use OTP IMEI: 351954009401772 Using SKEY: 45319575 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xFC0000 size: 0x030000... EEPROM backup in "C:\mobileEx\3.4\modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\MC60lg95Sw07_EEPROM_101224183833.bin " file. Write EEPROM addr: 0xFC0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
