12-04-2012, 04:11 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 200541 Status: Offline Thanks Meter: 1 | sign application error MXkey - Help please before, it has no problem at all. i tried to click on "sign application" it nothing happen... im now out of idea.. plz help... thanks alot anyway here is the link of picture http://www.freeimagehosting.net/r1h8x sorry, i tried upload the picture so it can show here but it couldn't. thanks for the help. |
12-04-2012, 04:23 | #2 (permalink) |
Major Poster Join Date: Dec 2009
Member: 1174311 Status: Offline Thanks Meter: 6 | Plese sir try to install your HTI with other pc and update your box with the sign application if succes copy your "mobileEx.xml" from folder C:\mobileEx\3.5 and paste with the computer you want to use (C:\mobileEx\3.5) |
12-04-2012, 05:18 | #5 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1644460 Status: Offline Thanks Meter: 44 | Check you mx box in this list , may be you are black listed http://forum.gsmhosting.com/vbb/f550...9/#post8973132 |
The Following User Says Thank You to atif ikram For This Useful Post: |
12-04-2012, 09:00 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Check Time & Date of your PC, Unistall Mxkey Application & Delete MobileEx Folder manually, Reinstall Mxkey Application & Sign Application, (Internet is must to sign) BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-10-2012, 09:27 | #8 (permalink) |
Member: 200541 Status: Offline Thanks Meter: 1 | thanks all the suggestion. problem solved today. uninstalled all the mxkey program and deleted all the folders restart my comp, reinstalled and there sign application works perfectly.tq... |
02-12-2017, 08:00 | #10 (permalink) |
Crazy Poster Join Date: Aug 2012 Location: kolkata
Member: 1800651 Status: Offline Sonork: [email protected] Thanks Meter: 20 | need mxkey update setup file, or only mobileEx (xml document) file. thnx in advance... |
