04-26-2010, 14:17 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 619463 Status: Offline Thanks Meter: 20 | simlock data corrupted SW Version: V 6.42 30-06-06 RH-59 (c) NMP 2600 Imei plain: ??????????????-? Product Code: 0525509 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 6A383D13CA9D23E6 PROFILE_BITS: 404D6F8EAAF6855B BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! what problem? pls help frnts |
04-26-2010, 14:27 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
b.r. | |
04-26-2010, 14:30 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | 1.Service > Imei & Security > Imei Rebuild > Repair SD 2.Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 3.Service > PM >load.PM.Super SD Auth.write PM imediately. |
The Following User Says Thank You to MMDEBILI For This Useful Post: |
04-26-2010, 15:31 | #4 (permalink) |
Member: 619463 Status: Offline Thanks Meter: 20 | Imei Easy Imei restore for DCT4 phones started. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 004A6EB8:2984DA60 ASIC type: 2 UEM Imei: Empty Flash Imei: 00000000000 Investigating flash imei ... Looking for backup for this phone ... ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 004A6EB8:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: RH-59 SW Version: V 6.42 30-06-06 RH-59 (c) NMP 2600 Imei plain: ??????????????-? Product Code: 0525509 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 6A383D13CA9D23E6 PROFILE_BITS: 404D6F8EAAF6855B BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
04-26-2010, 16:06 | #5 (permalink) | |
UEM Imei: Empty is it new one..? uem is empty.. | |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
