12-01-2012, 21:09 | #1 (permalink) |
Junior Member Join Date: Nov 2010 Location: Hungary
Member: 1449185 Status: Offline Thanks Meter: 0 | Simlock error Nokia 2730C Please help me! I flash new firmware nokia 2730C and before backup RPL! Everything was fine so far, but i restore RPL All ok but SIMLOCK ERROR! I work for about 10 hours and nothing! (all erase, backup old firmware, ...) :-( I CRY! :-(((((((((( I restore Simlock only error, ... PLEASE HELP ME! Thank you! |
12-02-2012, 02:32 | #3 (permalink) |
Member: 1449185 Status: Offline Thanks Meter: 0 | MXKEY [FT SCR2000 0], SN: C0839C9E Using device: HTI, FW ver: 00.48, SN: 0100A200 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E90020974690256A5F72E27308CAA466654897F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Original Imei: 35434304543776 Original Product code: 059B543 Bluetooth ID: E4EC10CEB9EB SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-578 (Nokia 2730 classic) SW version: V 10.40 27-04-10 RM-578 (c) Nokia Imei plain: 35434304543776-7 Product code: 0585305 Battery voltage: 4949 mV, current: 63 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR030102F201, ver: 005.005 SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Befor flashing backup ALL RPL. Yet ERROR! Why error? :-( Serius i cry! :-( My mobile not unlocket! If I unlocket now, that's help? (SHA saved) Or Send RPL anybudy? Thank you! Repair simlock: MXKEY [FT SCR2000 0], SN: C0839C9E Using device: HTI, FW ver: 00.48, SN: 0100A200 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-578 (Nokia 2730 Classic) SW version: V 10.40 27-04-10 RM-578 (c) Nokia Using cached productData. PUBLIC ID: 1E90020974690256A5F72E27308CAA466654897F PRIVATE ID: F7914970D2D501D74699D90B8F5BF34FAA339A71 Updating SIMLOCK ...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Last edited by drcyberg; 12-02-2012 at 02:41. |
12-02-2012, 06:57 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | What was the Phone status before Flashing ? Why you restore Backup RPL, do you Erased the Phone before Flashing ? Please clarify some details about this. BR, ZUBER |
12-02-2012, 15:15 | #5 (permalink) |
Member: 1449185 Status: Offline Thanks Meter: 0 | Yes, before flasing worked. Because not present Hungarian language (10.47V), and i flashing downgrade (10.40V). Backup RPL; full erased; flashing; restore imei; restore RPL, and than ERROR. PM all ok but error simlock restore. Now if can help in the unlock and simlock restore? Or what correct step? Thank you! |
12-02-2012, 17:31 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You Bricked the Phone by not Backing Simlock, You know, when have to Erase SL3 Phone, then Simlock Backup is must, So the only option is to Buy Factory RPL. BR, ZUBER |
12-02-2012, 17:56 | #7 (permalink) |
Member: 1449185 Status: Offline Thanks Meter: 0 | Okey, I buy Factory RPL. Where and who should buy it? I write message fastunlock member, but has not yet responded. Or else have to buy it? About how much the factory RPL? Thank you! |
12-02-2012, 21:39 | #8 (permalink) |
Member: 1449185 Status: Offline Thanks Meter: 0 | Why buy new RPL? My RPL is wrong or what? All OK but SIMLOCK ERROR! :-( I unlock my phone (not unlocked) and after restore simlock this is correct step or no? Do you want see my computer for TightVNC? Please! Thank you! |
12-02-2012, 21:58 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, You Backup RPL which not contains Simlock Data, If you Backup Simlock or Full PM, restoring can fix it, But Purchasing Factory RPL, Provider will provide you RPL File containing all necessary Certificates along with Simlock Data, Now you must be clear about what you done & how to fix it now. BR, ZUBER |
