07-22-2009, 12:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: China/USA
Member: 718425 Status: Offline Thanks Meter: 5,873 | SIMLOCK_DATA corrupted! Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! PhoneType:RH-112 SwVersion: V 03.00 14-11-08 RH-112 (c) NMP MCU file: rh112_003.000 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F7204F:2984DA60 Area [01000000-0101FFFF] erased in 2.188 s Area [01160000-0117FFFF] erased in 2.156 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F7204F:2984DA60 Area [01000000-0101FFFF] erased in 2.156 s Area [01160000-0117FFFF] erased in 2.156 s Programming ... Programming completed. |
The Following 4 Users Say Thank You to R@ZIB-BD For This Useful Post: |
07-23-2009, 10:13 | #6 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | Quote:
07-23-2009, 10:35 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | sim lock data corrupted only solved by unlock this set unlock is yet not supported by any device whenever unlocking will be available simlock data corrupted will be solved only by doing unlock conteact service needs unlocking to repair the simlock so wait till unlocking will come |
The Following User Says Thank You to cel_phon For This Useful Post: |
how repair SIMLOCK_DATA corrupted! | kumar_pvj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 17 | 05-17-2010 17:41 |
N85 SIMLOCK_DATA corrupted | antoniogonzalez | Universalbox | 2 | 08-06-2009 07:45 |
N85 SIMLOCK_DATA corrupted | godlfc | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-26-2009 09:45 |
6681 SIMLOCK_DATA corrupted!?? | mdmosheur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 07-05-2009 07:25 |
n95 SIMLOCK_DATA corrupted!?? | SAN INFOTECH | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 07-03-2009 05:51 |
