10-02-2011, 00:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Cameroon Age: 52
Member: 163755 Status: Offline Thanks Meter: 126 | Sl3 contact service 2730 ## (ANSWERED) Just to fine out this sl3(2730) after wrong flash the phone now display contact service any possibility of repairing it with mxkey. |
10-02-2011, 23:28 | #5 (permalink) | |
Member: 163755 Status: Offline Thanks Meter: 126 | Quote:
Thanks for the reply here is the log file of the self test below. Phone Type: SW version: ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N !NOT EXECUTED(03) 93 SECURITY N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 101 BTEMP N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 82 CDSP_PWR_DETECTOR_BIAS N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) | |
10-02-2011, 23:32 | #6 (permalink) | |
Thanks for the reply here is the log file of the self test below. Phone Type: SW version: ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N !not ready 69 BACKLIGHT Y passed 33 SIM_LOCK N !failed ! 93 SECURITY N !failed ! 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N !no signal 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 82 CDSP_PWR_DETECTOR_BIAS N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 75 CDSP_WCDMA_TX_POWER N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal Sorry the double posting. | |
10-03-2011, 01:15 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
press restore imei, if you have it. All be done automatically. and if no, you should buy factory RPL from Fast Unlocking. BR | |
10-03-2011, 11:13 | #8 (permalink) | |
Imei: 356058000000 Updating SIMLOCK(PA_SL3)...OK Updating WMDRM_PD...OK CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C60020F49F88C56EFFE852565AB376E4899A2C5 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! Phone type: RM-578 (Nokia 2730 classic) SW version: V 10.46 23-07-10 RM-578 (c) Nokia Imei plain: 356058000000 Product code: 0585335 Battery voltage: 4754 mV, current: 54 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356058030000000 Version: SIMLOCK SERVER Provider: Bell Mobility , Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3026100000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=302610 [Canada-Bell Mobility ], 2=CLOSED(GID1), DATA=302610 [Canada-Bell Mobility ] BLOCK2: 1=CLOSED(MCCMNC), DATA=20404F [Netherlands-Vodafone Libertel N.V. ], 2=CLOSED(GID1), DATA=20404F [Netherlands-Vodafone Libertel N.V. ] | |
10-03-2011, 11:59 | #9 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: Muyie Hape
Member: 1596237 Status: Offline Sonork: DijeMuyie Thanks Meter: 37 | Quote:
BF brow... | |
10-03-2011, 14:13 | #11 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 406 | Quote:
write pm 1.309 reapaire sd | |
10-03-2011, 21:17 | #13 (permalink) | |
When tick LOAD RFBB FROM SERVER and click writ log file below. NK module version: 1.21 NK applet version: 00.20 NK module ready. Market items is empty, please select the correct products path ! Please "Scan" or "BUS check" before any operation ... Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.205.25.180 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.205.25.180 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request | |
10-04-2011, 06:04 | #14 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | i don't see you use HTI box, that's why i suggest you the old way. - CS repair: press repair SD with HTI, all be done in one click. another work around CS repair w/o HTI: - load PM , press super SD auth, when done, press write |
The Following User Says Thank You to gbluez For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
