Old 07-07-2011, 16:43   #1 (permalink)
Member: 1584394
Thanks Meter: 24
Unhappy Socket error (10060): Connection timed out ERROR: request failed(ANSWERED)!
ERROR: request failed!
Old 07-07-2011, 20:25   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hello friend,
if i'm not forgotten, i suggest you to get HTI that time, right?
 IMEI: 355465040502540
 MEP:  mep-30669-001
 Factory Lock State: CLOSED
 MXKEY Serial: C0696666
 MEP2(Network,Active,2,8): 4239940736785016
 MEP3(Network Subset): 4987576219594572
 MEP4(Service Provider): 9937810991047465
 MEP5(Corporate): 1434845789371978
Unlock instructions:
 1. Insert SIM card
 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0)
 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card"
 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard
 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4)
  NOTE: You will not see any text appear on the screen while typing on step 3 and 4.
 6. You should be presented with a prompt "Enter Network MEP Code"
 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm
 8. Device is now unlocked.
  NOTE: Make sure you follow these or the instructions correctly.
If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded.
Nokia Datasuite Connection Failure Judesp Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-27-1999 09:36
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.17037 seconds with 9 queries
