03-06-2012, 17:12 | #19 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | Quote:
When I Erase phone and flash to low version phone goes to local and test mode with damage imei. But when I write RPL so phone does not power on nor goes to local or test mode. | |
03-06-2012, 19:21 | #20 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | Quote:
The simple solution is just flash the phone with current version MCU file, and flash PPM and CNT with lower version which have language you need. Example: 6303c already have firmware v10.12 that's only have english language. You want to change its languange to Urdu that supported by firmware v8.10. So what you need to do is just flash the phone with: MCU = v10.12 PPM = v8.10 CNT = v8.10 / v10.12 (its up to you, since CNT only contain default sound, image, theme and application) There no risk, and simplest way if you only want to change language. (tested many times) BR | |
03-06-2012, 19:34 | #21 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. first you try like that: So what you need to do is just flash the phone with: MCU = v10.12 PPM = v8.10 CNT = v8.10 / v10.12 (its up to you, since CNT only contain default sound, image, theme and application) There no risk, and simplest way if you only want to change language. (tested many times) bro. wrong, you had not tested, so first test yourself & post full logs, after that phone condition you dont tell we will understand what happen then. |
03-06-2012, 20:22 | #22 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
1. self experience learning by doing 2. you will never know until you read some confidential service bulletin released by KICS i use option 1 | |
03-06-2012, 21:29 | #23 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | mr. gluez, the link is for nokia employees, you have any idea how to log in or register, as i think it can improve our knowledge. thanks for you info.... |
04-06-2012, 08:08 | #27 (permalink) | |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | Quote:
Did you find a solution to this problem? I have problem with this:Rm625 Nokia 5228 sw 50.1....there is not a Hungarian language in him.Older sw. is not thawing out to put up! No ATF box......because it would solve it. | |
04-06-2012, 08:17 | #28 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | - make backup everything (PM, RPL). ensure your backup is GOOD. - full erase the phone. use erase file from here., or by get addr feature. - flash any version, restore your backup |
04-06-2012, 08:33 | #29 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | Did you test this solution? "When I Erase phone and flash to low version phone goes to local and test mode with damage imei. But when I write RPL so phone does not power on nor goes to local or test mode.." |
04-06-2012, 08:55 | #30 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
im sure he did test this solution using c3-00 rm-614, check http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ post your buscheck log bro, what is your phone type anyway, no clue at all bro br | |
