04-06-2010, 10:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | solution for 3110c security test failed, come here just do this....... 1) backup rpl and save it 2) full erase ur phone 3) flash ur phone again 4) open ur the backup rpl as notepad 5) delete all the data under the npc data... just leave the yellow color and delete all data and save it.. example: [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0544306 PSN=7G1249059 HWID=2003 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303534343334334300000000 NPC_DATA_2=0000000000000000000000009948E094B748974 7FCCC0300646F7242000000002B600108C39F6E56 NPC_DATA_3=2AF8890318A146CF741D9FF6C0E691EA16A7593 A9BB28832D7312A39F7ED668D2975DA7595F67699 NPC_DATA_4=029197390C321380DEAFCBE1000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3395280941092727FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=A7F6DCA31E00000000000000000000000000000 000000000000000000000000094CF4533B75265D6 NPC_DATA_7=514DBB436C42EB26013A56D89F8B77EB7A66661 9149D27449ED5E26DA8574244608CC6B128230D26 NPC_DATA_8=C6A1DF91C77EBD519F7154C9648A3DDC3B49D6F F2A58CBB1B325622A10014AF419A1E22C378ECB68 NPC_DATA_9=7A8BE2844688FFBE7369DBCE00C50936E0931DD 8E4305FA2388C696DFD95E30832B1CCE8D98E1661 CCC_DATA_1=4343434302004150010000009138E0942182024 675792D00EF3E9C00000060010000000000000000 CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035343433323143 CCC_DATA_3=090699450000000000000000010000000E00000 00000000000000000000000000000000000000000 CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000 00000000019A7FFE66095ADA9642936E87EA755B9 CCC_DATA_7=3DE48139152F82D7AB3B18F94D191ED9B50DC3E 96DAB6572437E0B69D8E83BDBED7472EA899F346D CCC_DATA_8=02BB7FB5B98EADF4B79396385DBA17179069AB3 9E3F6386A85834FD1030B2EB988784C9DAE51AF7C CCC_DATA_9=92B294EB303034287446DF9F0D73BAAABD203F0 0F9B7A0A3B9EBEBC039736DA1 HWC_DATA_1=43485743050041500100000093060297234D7E4 955400000646F7242000000000000000000000000 HWC_DATA_2=00000000000000002040010B332B7E56C53D711 E88EF1210ADE1BD34303534343332314300000000 HWC_DATA_3=00000000B941FF7BE3678FF61CA2B68B4EFBFA2 2FE7C537BEE6B89510D9A9E533DF38F497D27F85D HWC_DATA_4=253C7CB714488752FF3B12ADBEFCBB48D6D58D2 98C38A256D783965228BD9B9206111EC652528E4D HWC_DATA_5=C2DB7660B6A2D4A6BCBEF4D160D5588441DE14C 75A392A11E6A4939E52C9BE48D76F2AC472B23BDD HWC_DATA_6=4A551773BCD96C9E7BB3AD02 ============================================== 6) now write rpl that u edited 7) goto service >> IMEI and Security >> and select Simlock in left hand. 8) tick Make simlock rpl and press Update SpLock 9) now click IMEI rebuil in left hand u see. 10) Repaire SD 11) now goto pm 12) select pm 1 and 309 section and press SUPER SD Auth 13) now press write . if still same, u will see here... 14) goto phone test >> click various >> now press BB5 Certificate Validation you will see like this.. ccc and hwc is empty Reading RAP NPC (0x168 bytes) Original Product Code: 0544343 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x0 bytes) CCC empty ! Reading RAP HWC (0x0 bytes) HWC empty ! ===================================== then just write rpl without npc data made by mxkey ur problem solved 100%. enjoy.......... with best wishes... |
The Following 4 Users Say Thank You to khalidjan For This Useful Post: |
05-27-2010, 09:36 | #2 (permalink) | |
Junior Member Join Date: Jan 2010 Location: India,Jalandhar
Member: 1206040 Status: Offline Thanks Meter: 0 | Quote:
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
3110c - Security Test Failed ## (ANSWERED) | jesuraja | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 29 | 10-31-2011 15:00 |
3110c - Security Test Failed. Help! | [Shadab_M] | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-30-2010 09:43 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
mx key team 3110c security test failed | sanjayvikas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-31-2010 23:42 |
