Solution for DEAD PHONE after flashing with mobileEx 3.3 (rev1.7_fixed)!! Today I flashed Nokia 3110c with new mobileEx 3.3 (rev1.7_fixed), like many user complaint about dead phone after flashing with this version, mine got death too after i flashed with this new version. But i went ahead and check out different option and found out that when i flashed again with option FAST flash enabled (yes, i know that MX team recommend not to enable FAST flash with intel chip), the set then come alive and worked perfect, guys i think you should check with different models and post result here. BR, curvenger. |
hey can you upload the rev1.7_fixed to mediafire or 4shared? net surfing are very limited now here in my place... thanks |
Here it is, if you end up with death phone after flashing, try with option FAST flash enabled as I mentioned above OK. Here is 4shared direct download link ==> 4shared.com - online file sharing and storage - download mobileEx_setup_v3.3_rev1.7_fixed_20100322_.rar if it helps you, press the thanks button in the bottom right corner of the post. |
if phone goes dead just try nokia usb dead flashing it will be ok |
last i post when use MXKEY ver 3.3 rev 1.7 fixed is use "Fast Flash" just checked that ;) br, |
you write i flash 6300 thanks |
tested ... |
Havent notice that, where did you post it, my bad if i started already posted thread. :o:p |
not your bad , but maybe somebody lost the searching button :) br, |
same here afdter usb flash my n73 power on but lcd blank at all....help!! i try flash with orther tools also same... now i use back mxkey flash it show npc data empty how to slove it .... |
Do you have backup? can you post log here? |
i teats 2 phone n73 after flash is black lcd when i flash with jaf it ok what wrong |
NPC data does not get deleted by itself unless you reset it yourself, or it can be corrupted due to mishandling, like water damage.. etc .. Sometimes it happens after incomplete flashing and the software will report it as blank.i already experienced that before. Try flashing again with option FAST flash ticked and with newest firmware available and post log here OK. |
