Old 03-29-2010, 18:33   #1 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Wink Solution for DEAD PHONE after flashing with mobileEx 3.3 (rev1.7_fixed)!!
Today I flashed Nokia 3110c with new mobileEx 3.3 (rev1.7_fixed), like many user complaint about dead phone after flashing with this version, mine got death too after i flashed with this new version. But i went ahead and check out different option and found out that when i flashed again with option FAST flash enabled (yes, i know that MX team recommend not to enable FAST flash with intel chip), the set then come alive and worked perfect, guys i think you should check with different models and post result here.
BR,
curvenger.
The Following 3 Users Say Thank You to curvenger For This Useful Post:
Old 03-29-2010, 18:42   #2 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 631
hey can you upload the rev1.7_fixed to mediafire or 4shared?
net surfing are very limited now here in my place...
thanks
Old 03-29-2010, 18:49   #3 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Here it is, if you end up with death phone after flashing, try with option FAST flash enabled as I mentioned above OK.
Here is 4shared direct download link ==> 4shared.com - online file sharing and storage - download mobileEx_setup_v3.3_rev1.7_fixed_20100322_.rar
if it helps you, press the thanks button in the bottom right corner of the post.
The Following User Says Thank You to curvenger For This Useful Post:
Old 03-29-2010, 19:41   #4 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
if phone goes dead just try nokia usb dead flashing it will be ok
Old 03-29-2010, 21:01   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
last i post
when use MXKEY ver 3.3 rev 1.7 fixed is use "Fast Flash"
just checked that
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-29-2010, 21:26   #6 (permalink)
Member: 197485
Thanks Meter: 19
you write
i flash 6300
thanks
Old 03-29-2010, 21:52   #7 (permalink)
Member: 201432
Thanks Meter: 38
Originally Posted by mobileex-team View Post
last i post
when use mxkey ver 3.3 rev 1.7 fixed is use "fast flash"
just checked that
br,
fix your fixed better )))
Old 03-30-2010, 01:48   #8 (permalink)
Member: 293509
Thanks Meter: 10
indeed sir,this will solve the problem....for dead units...after flash...
tested ...
Old 03-30-2010, 10:04   #9 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Originally Posted by MobileEx-Team View Post
last i post
just checked that
br,
Havent notice that, where did you post it, my bad if i started already posted thread.
Old 03-30-2010, 10:08   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
not your bad ,
but maybe somebody lost the searching button
br,
Old 03-30-2010, 10:49   #11 (permalink)
Member: 149041
Sonork: 100.114578
Thanks Meter: 61
same here afdter usb flash my n73 power on but lcd blank at all....help!! i try flash with orther tools also same...
now i use back mxkey flash it show npc data empty how to slove it ....
Old 03-30-2010, 11:22   #12 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Do you have backup? can you post log here?
Old 03-31-2010, 02:55   #13 (permalink)
Member: 293509
Thanks Meter: 10
it happened to me also..in my 7219c unit...i asked some help but it seemed that nobody is willing to help me...
Old 03-31-2010, 12:06   #14 (permalink)
Member: 197485
Thanks Meter: 19
i teats 2 phone n73 after flash is black lcd
when i flash with jaf it ok
what wrong
Old 04-01-2010, 11:49   #15 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
NPC data does not get deleted by itself unless you reset it yourself, or it can be corrupted due to mishandling, like water damage.. etc .. Sometimes it happens after incomplete flashing and the software will report it as blank.i already experienced that before. Try flashing again with option FAST flash ticked and with newest firmware available and post log here OK.
solution for dead k608i after bad testpoint servtelgsm Sony Ericsson 6 02-19-2006 21:56
any solution for dead c975 after flash GSM SHADOW Motorola P2k 2 06-18-2005 10:53
help me for c25 dead phone after flash alf007 x1x to x45/x50 1 01-24-2002 11:56
C 28 v. 61 solution for dead phone Mtelko x1x to x45/x50 4 04-07-2001 20:29
Do have solution for DEAD phone? Charlie Old Ericsson Phones & Sony Phones 6 04-11-2000 02:14
Page generated in 0.38231 seconds with 8 queries
