Old 03-17-2010, 11:10   #1 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,957
..::Solution / Information ::.. about SL3 Contact Service
Phone Type: RM-495 (Nokia 5130c-2)
SW Version:
V 05.80 18-12-08 RM-495 (c) Nokia
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353223034396342
Version:
SIMLOCK SERVER
Provider: Nokia Test, Country:
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
how u can i repair this error ?
Just Do normal SX4 than write PM1 and PM309.
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Version:
SIMLOCK SERVER
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
Just Do normal SX4 than write PM1 and PM309. ( don't care about Simlock invalid as all BLOCK are open SL data not corrupted)
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed
SL data Corrupted
How can i repair mobile in this state?
No. u can repair this state of mobile as SL data is corrupted too. If u have Full RPL backup with Mxkey that yes . If no than Only Nokia RPL service is the solution.
SW Version:
Imei plain:
123456754321-?
Product Code:
0577793
Language Pack:
- not available.
imei invalid or plain
SIMLOCK invalid!
SUPERDONGLE_KEY seems to be invalid
mobile power off after 3 mins
SIMLOCK_TEST failed
SL data Corrupted
How can i solve this Error?
U can't repair the imei of the mobile for that u have to use Nokia RPL service.
but u can get this mobile out of contact service.
The Following 36 Users Say Thank You to hasnain For This Useful Post:
Old 03-17-2010, 11:17   #2 (permalink)
Member: 681954
Sonork: 100.1582852
Thanks Meter: 46
Wowwww
very goodddd
br
Old 03-17-2010, 11:17   #3 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,423
SIMLOCK invalid!
SUPERDONGLE_KEY invalid
SIMLOCK_TEST failed
SECURITY_TEST pass
Then any solution
Old 03-17-2010, 11:18   #4 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 633
usefull information
another good work form mr hasnian
Old 03-17-2010, 11:20   #5 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,957
Originally Posted by Riz000 View Post
SIMLOCK invalid!
SIMLOCK_TEST failed
SECURITY_TEST pass
Then any solution
use nokia RPL service in this case
The Following 3 Users Say Thank You to hasnain For This Useful Post:
Old 03-17-2010, 11:33   #6 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 398
and what about this problem last weak a coleg min bring me 5130 rm-495 who has downgrad with hwk from v 7,91 to 6.94 the phone as you know dead i tried severeal time with diferent tools the resultat is the mcu and ppm flash ok the cmt on the midle stoped and gave error cannot countinu full flash
is there any body can help the phone not in my hand but if you can help i will get the phone pack I belive some one of MXKEY can help (NOTE:no info from the phone when gave scan)
THANKS TO ALL espicialy to MR HASNAIN
Old 03-17-2010, 11:46   #7 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
this is good report those who can encounter with this problem this is your solution or option good job hasnain
Old 03-17-2010, 11:46   #8 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 394
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK_TEST passed
Version:
SIMLOCK SERVER
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Version:
SIMLOCK SERVER
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed
SL data Corrupted
SW Version:
Imei plain:
123456754321-?
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed
SL data Corrupted
old story.
post here only valid solution then post here otherwise ur solution is posted here many many times
Old 03-17-2010, 11:54   #9 (permalink)
Member: 587774
Thanks Meter: 11
useless solution....phone will out of contact service but it will turn to auto shutt off....
Old 03-17-2010, 11:56   #10 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 398
But this is usfull for all Bro
Originally Posted by klmamn View Post
old story.
Post here only valid solution then post here otherwise ur solution is posted here many many times
thanks alot again to mr hasnain
Old 03-17-2010, 12:17   #11 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,957
old story.
see alot of posts regarding tis error u will found this week
every day alot of post regarding 5130 contact service.
so this post is for them not for professionals
i want to arrange the Mxkey Nokia Thread.
want to keep all posts regarding Contact service of SL3 5130 , 6700 .....
but still Thanx for ur comments because ur feelings Shows me that i am working good
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 03-17-2010, 13:12   #12 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 398
please upload me pm 1-309 for 5130
thanks
Old 03-17-2010, 13:23   #13 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,957
ALL pm files here
PM FILES OF BB5 : just download them from this link and enjoy
MEGAUPLOAD - The leading online storage and file delivery service
The Following 4 Users Say Thank You to hasnain For This Useful Post:
Old 03-17-2010, 14:55   #14 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,005
what about it
Imei plain: 35604003196437-8
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
The Following User Says Thank You to sajidali For This Useful Post:
Old 03-17-2010, 14:58   #15 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,957
Originally Posted by sajidali View Post
what about it
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK invalid!
SIMLOCK_TEST failed
SL data Corrupted
how to remove SL3 contact service & sp data corropted shimul_777 Nokia Base Band 5 ( BB-5 ) 37 09-14-2011 03:11
5310 sl3 contact service klodi Nokia Base Band 5 ( BB-5 ) 6 08-10-2009 17:03
5310 sl3 contact service plz hlp saeed ahmed Nokia Base Band 5 ( BB-5 ) 3 05-12-2009 22:12
Can any one tell about the coming sl3 contact service solution usman_ali Nokia Base Band 5 ( BB-5 ) 6 04-08-2009 22:11
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.57777 seconds with 9 queries
