06-28-2009, 12:27 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 946569 Status: Offline Thanks Meter: 326 | =Solution= Mx-Key Software and Antivirus Problem! here how to make mobilEX directory as exclusions; Kaspersky: 1. Click on Kaspersky settings located top right of the window. 2. Click on Protection in the left hand pane 3. Click on Trusted Zone button in the General section 4. Click on the Exclusion masks tab 5. Click the Add button 6. Click on the Specify link 7. Click on the Browse button to locate the file or directory you wish to exclude 8. If your directory contains folders you wish to exclude click on Include subfolders and click OK 9. Click on the checking task selected link to switch task to any NODE32( ESET) 1. Locate the nod32 icon on the Taskbar 2. Left click on the nod32 icon located on the Taskbar 3. Click on Setup option on the left side. . 4. Go down to the bottom of the nod32 window and toggle to "advanced mode".5. Go to "edit exclusions' and click "add". 6. In the Browse for Folder window, locate the mobilEx.exe (default location is: C:\mobileEx\3.2) choose the file and then press ok 7. In the “setup” you will see the file chosen, then press OK br |
The Following 3 Users Say Thank You to 1NOKIA1 For This Useful Post: |
06-28-2009, 16:18 | #2 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Delhi & NCR (INDIA)
Member: 800668 Status: Offline Sonork: 100.1590720 Thanks Meter: 882 | bro always use norton for mobile software repairing i am using norton from 4 years if you want then contact me br shashank |
06-29-2009, 03:45 | #3 (permalink) |
Freak Poster Join Date: Apr 2007 Location: land of no return
Member: 486967 Status: Offline Sonork: none Thanks Meter: 17 | your solution does not work on new versions of anti viruses! even if you put in exclusions or trusted. it will work only at first open of the OS when you try to use it again it wont work try this instead,tested it 100% http://forum.gsmhosting.com/vbb/showthread.php?t=776484 |
New MX-Key Software Does Not Startup(ANSWERED) | digital_park | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 52 | 08-18-2011 19:53 |
REPORT MX-Key bugs and problems here... | Burnt Cobba | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-10-2010 09:07 |
mx key software | ramteja | Nokia Hardware & Hardware Repair | 0 | 10-09-2009 16:46 |
100% working mx-key software with all system protection securities.... | sahil00150 | Nokia Base Band 5 ( BB-5 ) | 5 | 08-14-2009 11:24 |
Could This Be Possible To Add To MX-Key Software | amar22ado | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-17-2009 21:12 |
