Old 03-25-2010, 17:38   #1 (permalink)
Member: 719399
Thanks Meter: 227
Solution for No network in Nokia 5000
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
Rpl backup already exist (C:\mobileEx\3.3\data\backup\35679702569440_BACK.r pl).
Processing file: rm362__06.31.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 11.87 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8
Performing Flash Authentication ...OK
UEM ID: 00852385:3B8ADA60
Area [01000000-0101FFFF] erased in 0.593 s
Area [01020000-01BFFFFF] erased in 56.625 s
Flash programming ...
Programming completed in 4 min 52.703 s
File Processed in 6 min 7.172 s
Processing file: rm362__06.31.image_ea_pur as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 5.88 MB
UEM ID: 00852385:C5A4DA78
Area [02180000-02E7FFFF] erased in 1 min 4.313 s
Area [02E80000-02FBFFFF] erased in 7.093 s
Converting UCP blocks to 128 K.
Programming completed in 2 min 27.750 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.156 s
File Processed in 4 min 16.187 s
Processing file: rm362__06.31.ppm_ea as PPM
[DCT4,DCT4 ALGORITHM] size: 3.98 MB
FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH
UEM ID: 00852385:2984DA60
Area [01C00000-0217FFFF] erased in 27.140 s
Programming completed in 1 min 42.265 s
File Processed in 2 min 26.469 s
Flashing completed in 12 min 51.156 s
After Flash Processing ...
Updating Product Code OK.
Reseting Factory Values OK.
Uploading PM
Writing PM from Node ...
Completed in 0.000 s
PhoneType:RM-362
SwVersion: V 06.31 24-03-09 RM-362 (c) Nokia
MCU file: rm362__06.31.mcusw
Trying to find patch position ...OK
Area [01000000-0101FFFF] erased in 0.594 s
Area [01220000-0123FFFF] erased in 0.594 s
Area [01440000-0145FFFF] erased in 0.562 s
Area [014A0000-014BFFFF] erased in 0.578 s
Area [01BE0000-01BFFFFF] erased in 0.688 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 53.563 s
Phone Type: RM-362 (Nokia 5000d-2)
SW Version: V 06.31 24-03-09 RM-362 (c) Nokia
Imei plain: 35679702569440-8
Imei OTP: 35679702569440
Product Code: 0566560
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: EA
Language Pack:
- not available.
Imei net: 35679702569440
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 28 min 32.234 s
1.Flash the phone with the latest mcu,ppm,cnt. V 06.31 24-03-09 RM-362
2.Before you'll start flashing tick After flash processing and tick: Set product code, Set product profile,sp unlock,Reset(chose full factory),PM which can be found here :
http://forum.gsmhosting.com/vbb/f550/dear-mr-manole-plese-help-me-957248/index2.html#post5610044
Thanks to:
lilong_lee
MarkGsm45
Phone has network now and is working great. Iused Nokia 5000 cable same as 2630.
Solution for boot error DCT4 Nokia 5000 gerdzio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-28-2010 06:13
no network in nokia 6101b tarey888 Nokia Digital Core Technology 4 ( DCT-4 ) 0 10-30-2006 09:11
no network in nokia 6101b tarey888 Nokia Digital Core Technology 4 ( DCT-4 ) 2 10-30-2006 08:59
Razor V3 any solution for NO NETWORK ON 900/1800Mhz laboratory_gsm Motorola Hardware Repair 10 09-06-2006 01:33
Diagnosing SW for no network in nokia garutech Nokia Multimedia 11 10-23-2004 11:27
Page generated in 0.29313 seconds with 8 queries
