01-17-2010, 13:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Morocco/FBS
Member: 537213 Status: Offline Sonork: 100.1577391 Thanks Meter: 362 | Solution ''Sign Apllication'' For AMD Prossesor! 100% working u want sign application and u get only this msg !! Starting application sign request ... Connecting server [ca.mxkey.biz] OK, Secure Login ... Solution Sign application in intel PC then copy mobileEX.xml from C:\mobileEx\3.3 and past in other AMD PC where not work singing application in C:\mobileEx\3.3 and the software will working without request sign application br www.gem-flash.com |
The Following 8 Users Say Thank You to DARIFBS For This Useful Post: |
01-17-2010, 13:24 | #2 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 49
Member: 63120 Status: Offline Thanks Meter: 58 | is 50% solution after this way sign trick, sever not can be founded on amd pc, sx4 not work, online unlocking not works..... so , nothing get after sign on other intel PC br.skkeptik |
01-17-2010, 13:43 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: E.A.P & E.A.S
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | @All be patience please... I think not have "something" with AMD Athlon processor ... Look here : http://forum.gsmhosting.com/vbb/showthread.php?t=888606 So the poll is closed, mean mxkey team have solution already ... thanks |
01-17-2010, 18:51 | #7 (permalink) |
Member: 63120 Status: Offline Thanks Meter: 58 | heeeeeh is not so shure please post here log of unlock any phone , or check servers status on 3.3 1.1 on amd processor, easy clone sign file from intel, but is not usable for unlocks...... simple, codder not make good job in comunication after 3.2 , after that version always problem with serbvers unlocking or sx4, so codder must cjeck code again, or give chace to us to find a bug in commmunication. i found a way to mix modules and exes , 3.2 ols shell, with new module, but not have phone to test it . please Alim........ fix this **** , many of us use amd , personaly i have 2 amd-s and 3 intel, but all nokia stuff is on sempron, and other boxes not have any problems. recompile exe on amd platform, or check communication protocols, bug is stupid , and not exist in 3.2 . as Manole say , you warned about this bug before new year, and you doo nothing. for example. 3.2 version online unlock 6220 easy , and 3.3 1.0 , not make codes with server....... and some other phones. br. skkeptik |
The Following User Says Thank You to skkeptik2 For This Useful Post: |
01-17-2010, 21:27 | #9 (permalink) |
Member: 63120 Status: Offline Thanks Meter: 58 | dongle plug.unplug Man, this is cheap tool, but not a toy, if you just unplug and plug dongle, it means you not see dongle before ....... or pc ask you for new drivers.all that is not important if you see serial number in software, problem is communication part of main exe, it must be rewriten, becouse is based on st... routine that not 100% compatible with amd chipset.that i sreason why not work sx4 or online unlock after trick to sign soft on intel platform. br. SKKEPTIK please corect me with prove if i im in wrong...... paste here log online unlocking and picture of device manager with type of CPU. so maybe only chipset, is problem not cpu, if amd on some laptops works , on some chipset , i can confirm no one nforce chipset with any amd cpu not sign and not comunicate with serverin any way, maybe integrated nvidia controler lan or wireless are probelm ? i suppose must of us use cable conections...... so CPU or Chipset is reasona why not sign our application. Tomorow , i will ty intel on nvidia chipset , and post here result. |
Torch For N70 Tested 100% working | mani6 | Nokia Multimedia | 3 | 05-13-2010 13:23 |
Solution MXKEY ''Sign Apllication'' For AMD Prossesor! 100% working >> | ..::AdnanRaj::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-19-2010 16:15 |
RAPIDSHARE (Free TuToRials for Free Users) 100% working | Uwo_jj | Off Topic Zone | 3 | 11-19-2008 14:43 |
All Nokia for SAGEM 835 100% working!!! | mihut | Infineon C16X M51 & ARM7 M52 BASED | 6 | 05-21-2000 15:42 |
