Old 02-10-2010, 09:33   #1 (permalink)
Member: 1058944
Sonork: 100.1582347
Thanks Meter: 217
Arrow Sorry, Unable to find bootloader for this RAP ID !
HI Brothers,
I have got 6300 nokia when put on the phone ask for accept, when accept it goes on CONTECT SERVICE and goes off.
Its info and other things are here every where problem can not take PM Authration and also BUS CHECK faild.PLEASE NEED HELP>
Phone Type: RM-217 (Nokia 6300)
SW Version: V 06.60 21-05-08 RM-217 (c) Nokia.
Imei plain: 35393301835183-8
Product Code: 0546425
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
Imei net: 353933018351838
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
BUS CHECK:
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0CC0010DD03800584D2579890065C0AFA5821F25
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
For PM Says.
Socket error (11001): Host not found
Please need URGENT help.
Thanks
Br, Raja
Old 02-10-2010, 09:37   #2 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 395
repair simlock and sd after that write pm with super sx auth
Old 02-10-2010, 09:41   #3 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 816
For bus check problem just use good quality cable to get local or test mode
and after that reapir simlock and super dongle.
Old 02-10-2010, 10:00   #4 (permalink)
Member: 1058944
Sonork: 100.1582347
Thanks Meter: 217
HI brothers,
Phone is in LOCAL MODE, When Repair Simlock gives this error always..
"""Simlock update faild or something went wrong, would you loke to resotre simlock data from backup?"""
Yes or no. On both cases same result.
Urgent Help.
Thanks
Br, Raja
Old 02-10-2010, 10:18   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
try with standart metods
REPAIR SIMLOCK - Determind first what SL level you got
> Choose Repair SIMLOCK
> Tick make SIMLOCK RPL
> Click Repair SPLock
if have error on repair simlock
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
br,
Old 02-11-2010, 13:28   #6 (permalink)
Member: 1058944
Sonork: 100.1582347
Thanks Meter: 217
Thumbs down Same problem.
> Click Repair SPLock
1. Backup RAP NPC
2. FULL ERASE
4. Restore IMEI
5. Repair SPLock
6. Repair SD
7. Super SD Auth
br,
INFO:
Phone Type: RM-272 (Nokia 3500c)
SW Version: V 05.51 06-09-07 RM-272 (c) Nokia.
Imei plain: 35983001547360-3
Product Code: 0549248
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359830015473603
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BUT can not take RAP> RPL BACKUP.
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1480020E22FD7A56B22AD19E823FBC4EA3355A2D
ASIC MODE ID: 00
ON Both phones 3500c and 6300 same problem and cannot solve please help me.
Thanks
Old 02-11-2010, 14:17   #7 (permalink)
sandhu36's Avatar
Member: 387696
Thanks Meter: 161
write only 1 and 309 pm sx4 solve SECURITY_TEST failed
Old 02-11-2010, 16:50   #8 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 387
Originally Posted by GSM-STUDENT View Post
INFO:
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Thanks
make sure you have given correct pth to Mobile EX software that is
C:/program files/ Nokia / Phoenix/ Flash
All phones pick up the loader from this path
try this and post result
br
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 02-11-2010, 17:25   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
Flash loader issue,
fix your problem, click here
Old 02-11-2010, 17:30   #10 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Originally Posted by gbluez View Post
Flash loader issue,
not fixed bus check ok also rpl bkp
Version from phone: 35.0.001
Version from file: 35.0.001
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.12027, Date: 06-02-2010
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 2D24AE18B2C86EF863659040B123D454C11CD8D6
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15500109F6740052DAD68A026D4C4299A58C77DE
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
Reading RAP NPC (0x1B8 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Reading APE NPC (0x200 bytes).
Reading APE VARIANT (0x0 bytes).
Reading APE CCC (0x200 bytes).
Reading APE HWC (0x200 bytes).
Flash Imei: 35684202625097
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
NPC_DATA saved OK
VARIANT_DATA is empty.
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "E:\3.3\data\backup\RPL\BB5_35xxxxxxxxxx_BACK. rpl"
Processing file: RM-320_35.0.001_PR.C0R as MCU
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 69.48 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
Supported APE Ids: 24200705
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Flashing terminated with error(s) in 1 min 14.620 s
RX Buffer: 0400000000B172
n86 buscheck Sorry, Unable to find bootloader for this RAP ID ! godlfc MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-21-2010 07:05
Sorry, Unable to find bootloader for this RAP ID !? mamepap MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-20-2010 05:44
e63 Sorry, Unable to find bootloader for this RAP ID ! godlfc MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-30-2010 10:28
Sorry, Unable to find bootloader for this RAP ID ! Jilani001 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-23-2010 05:16
Sorry, Unable to find bootloader for this RAP ID ! Deepakranasaria MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-09-2010 11:07
Page generated in 0.41607 seconds with 8 queries
