05-20-2010, 16:34 | #34 (permalink) |
Freak Poster Join Date: Feb 2007 Location: ??????
Member: 446199 Status: Offline Thanks Meter: 40 | I cant connect 2 the server i am using windows 7 does it fully support it or it still has problems .I tried it on my pc which runs on win XP is works fine connects 2 the server with no problem.........Need Help THX in ADV |
The Following User Says Thank You to vipimg For This Useful Post: |
05-20-2010, 17:48 | #36 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 570193 Status: Offline Thanks Meter: 31 | PROBLEM-SD INVALID......REPAIRED SD SUCCESSFUL.....THEN 'SECURITY TEST FAILED'....CAN'T REPAIR ...BECAUSE SUPER SD AUTH/PMM AUTH NOT WORK (seril no co801273 = fw version 00.20 counter remain 87.50 = licenses o=true,1=true ,2=treu , dct4plus license true ) |
The Following User Says Thank You to mutunmobile For This Useful Post: |
05-20-2010, 22:22 | #37 (permalink) |
Major Poster Join Date: Jul 2008
Member: 814444 Status: Offline Thanks Meter: 4 | good lord Manole first to congratulate you for such great project second tell you five days since I came over here having a problem with the key the drawback is the next I had to reinstall the latest version software and want to use the program again asked me to give in Sing Application click there and gave the server gives me this error Starting application sign request ... [UnauthorizedFault] Card [C0809A7D] is BLOCKED (case id=0xCC05) there I leave my data mxkey Serial: C0809A7D FW version: 00.20 Counter remain: 98,73% Licenses: 0 = True 1 = True 2 = True DCT4PLUS License: True - Registered to: softwaregsm I hope I can help hope I'm not bothering or disturbing their work do not know if this is allowed but I was the only way I've found so far my msn is [email protected] there you can send any responses or here in the forum thanks |
The Following User Says Thank You to JUANP-86 For This Useful Post: |
05-21-2010, 12:15 | #38 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | 1. Make sure you have latest version installed 2. Your MXKey Dongle is registered in server and not blocked. Buy only from Authorized Distributor or Resseller 3. Check your internet connection, include firewall and antivirus and check server list. 4. Do clean install, if you know what i mean and do sign apps again. Check Your Credits Good Luck |
05-21-2010, 13:04 | #39 (permalink) |
Freak Poster Join Date: May 2009 Location: Poland
Member: 1031096 Status: Offline Thanks Meter: 77 | Nokia 2600c unlock ok: Code: Imei net: 35417803247009 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 26006000687xxxxx PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 26006F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-340_354178032xxxxx_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 354178032xxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-21-2010, 14:23 | #41 (permalink) |
Insane Poster Join Date: Jan 2008 Location: Patna,Bihar
Member: 685636 Status: Offline Thanks Meter: 128 | mx key sign app problem sir manole i am trying many times to sign app with 3.4rev1.0 by usb modem.i am unable to do this.if i connect BSNL BROADBAND then i can eaisly sign app and all work properly. can u clear what can i do , if i have only usb model |
05-21-2010, 15:47 | #43 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Here, there & Everywhere.....
Member: 110575 Status: Offline Thanks Meter: 98 | Until now can't SIGN APPL my ACTIVATED dongle... Try to install to different PC, and also put on the Laptop, still cannot sign appli. tia |
Anyone from Poland? Need help... | dito | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-28-2000 20:49 |
How can i get IMEI Number from a nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-10-2000 18:47 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
