sr gbluez (ANSWERED) how are you, your team as part of hti not tell me you would know that the problem occurs on my mxbox c boot errors I changed the usb cable and nothing, firmware update, try another pc with other cables but always boot error at startup Boot error: CC CC CC 00 |
hi, what is the phone condition? can ufs boot your phone with the same cable? BR |
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C08541DC Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.4.16.0 , NTMP ver: 2.6.2.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) Boot error: CC CC CC 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C08541DC Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.4.16.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000F1606:DA3BDA66 ASIC type: 11 UEM Imei: 01158900202856 Flash Imei: 01158900202856 MasterCode: 2717247420 RPL saved to "C:\mobileEx\3.5\data\backup\01158900202856_BACK.r pl" Phone Type: RM-259 (Nokia 2760) SW Version: V 05.20 06-12-07 RM-259 (c) Nokia Imei plain: 01158900202856-0 Imei OTP: 01158900202856 Product Code: 0553117 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: UB Language Pack: - not available. Imei net: 01158900202856 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 3340201549764300 PROFILE_BITS: B00000000001000B BLOCK1: 1=CLOSED(MCCMNC), DATA=334020 [Mexico-Telcel ] that kind of answer |
