Old 06-07-2011, 18:47   #1 (permalink)
Member: 773102
Thanks Meter: 24
sr gbluez (ANSWERED)
how are you, your team as part of hti not tell me you would know that the problem occurs on my mxbox c boot errors I changed the usb cable and nothing, firmware update, try another pc with other cables but always boot error at startup
Boot error: CC CC CC 00
Old 06-07-2011, 19:09   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
hi,
what is the phone condition? can ufs boot your phone with the same cable?
Old 06-07-2011, 19:14   #3 (permalink)
Member: 773102
Thanks Meter: 24
Originally Posted by gbluez View Post
hi,
If the log here
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C08541DC
Using device: HTI BOX, FW ver: 00.08
Driver: FTDIBUS, ver: 2.4.16.0 , NTMP ver: 2.6.2.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.4.16.0
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 000F1606A3BDA66
ASIC type: 11
UEM Imei: 01158900202856
Flash Imei: 01158900202856
MasterCode: 2717247420
RPL saved to "C:\mobileEx\3.5\data\backup\01158900202856_BACK.r pl"
Phone Type: RM-259 (Nokia 2760)
SW Version: V 05.20 06-12-07 RM-259 (c) Nokia
Imei plain: 01158900202856-0
Imei OTP: 01158900202856
Product Code: 0553117
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: UB
Language Pack:
- not available.
Imei net: 01158900202856
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 3340201549764300
PROFILE_BITS: B00000000001000B
BLOCK1: 1=CLOSED(MCCMNC), DATA=334020 [Mexico-Telcel ]
that kind of answer
Sr. Zulea, you can read this!! plutonn Phoenix Black Box 0 01-10-2006 01:00
Sr. no. automatic change Ahsan Redbox 0 11-25-2004 14:10
To moderators, specially Sr Drug Store menintest Off Topic Zone 2 09-18-2004 03:33
T68i _EMEA2 en / cz / hr / sr / sk / sl Akyboy Sony Ericsson 1 10-22-2003 05:34
Page generated in 0.27962 seconds with 8 queries
