Old 05-12-2010, 09:26   #1 (permalink)
Member: 629860
Thanks Meter: 53
still waiting for solution ..1208 hang and power of after 10 seconds.
dear members ...have flashed with new and old version .give pm and unlock too...but the prob is not solved...the set power on and also take network service ok but then hang and power offffffffff...
there is one thing when i on the light then the set work ok ...but when i try to call and then light is off automatically and set is hanged ...any solution pls
waiting for response
Old 05-12-2010, 10:27   #2 (permalink)
Member: 1300911
Thanks Meter: 119
make full erase using jaf erase manager then flash again with lower version then write tested good permanent memory unlock set full factory setting!
if problem persist then you have to rehot flash ic!
post result!
Old 05-12-2010, 10:30   #3 (permalink)
pawans's Avatar
Member: 346345
Sonork: jhon18
Thanks Meter: 56
hi mates.. the problem of your is cpu... try to reheat or replace..........
Old 05-12-2010, 13:18   #4 (permalink)
Member: 709604
Thanks Meter: 173
try it this solution
Old 05-12-2010, 15:37   #5 (permalink)
Member: 1299960
Thanks Meter: 36
give some hot air to the FLASH ic with good liquid flux and post result
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.17165 seconds with 9 queries
