06-15-2013, 16:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NICE MOBILES Age: 35
Member: 1293519 Status: Offline Sonork: 100.1596500 Thanks Meter: 169 | Successfull flash nokia c2-05 mx key Using device: USB ROM Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL) Processing file: rm724__08.73.mcusw Downloading item CODE:rm724__08.73.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.441 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.411 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.630 s Erasing area 0x40280000-0x41ABFFFE ...OK Programming completed in 37.898 s Checksum verified (0xEA48) Processing file: rm724__08.73.ppm_c Downloading item CUSTackage_c.ppm_ebl_psi.fls, num block: 1, size: 4.60 MB Erasing area 0x41B40000-0x41FD95E6 ...OK Programming completed in 6.802 s Checksum verified (0x138F) Processing file: rm724__08.73.image_c_dgray_059F9X8 Downloading item CUSTackage_c_dgray_059F9X8.image.fl , num block: 1, size: 15.25 MB Erasing area 0x42240000-0x43E1FFFE ...OK Programming completed in 21.235 s Checksum verified (0x6376) Total time for flashing process(boot+erase+write) was 3 min 52.933 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-05 USB Phonet, PORT_ID: 35738904130XXXX Verifying communication to device OK. Phone type: RM-724 (C2-05) SW version: V 08.73 29-05-12 RM-724 (c) Nokia Imei plain: 3573890413XXXXX-3 Product code: 059M0R3 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 01022C00003005, ver: RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-724_357389041306693_15_06_13_195052_SIM.RPL" Imei net: 35738904130669 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.308 s |
