01-28-2011, 08:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Bulgaria,Silistra
Member: 230266 Status: Offline Thanks Meter: 34 | Successfully Unlocked N97 mini 12 hours SW Version: V ICPR72_09w28.6 09-09-09 RM-555 (c) Nokia Imei plain: 35831503164874-4 Product Code: 0591759 ApeCoreSw: v 10.0.020 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358315031648744 Version: SIMLOCK SERVER Provider: Vodafone España, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21401F, DATA=21401F [Spain-Vodafone España, SAU ] BLOCK 2: 1=LOCKED (MCC+MNC): 21401F, DATA=21401F [Spain-Vodafone España, SAU ] SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 #pw+ 325942719527680 +1 # #pw+ 737432235800338 +2 # #pw+ 735054130744725 +3 # #pw+ 169051808121052 +4 # #pw+ 295647902732834 +5 # #pw+ 841704507812125 +6 # #pw+ 662227164798337 +7 # Codes file saved to: C:\mobileEx\3.4\data\SL3\358315031648744_SP_CODES. txt Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Reading Simlock info ... Imei net: 358315031648744 Version: SIMLOCK SERVER Provider: Vodafone España, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=21401F BLOCK 2: 1=OPEN, DATA=21401F |
The Following User Says Thank You to onzirado For This Useful Post: |
01-28-2011, 19:27 | #7 (permalink) |
Member: 230266 Status: Offline Thanks Meter: 34 | |
01-29-2011, 08:12 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010) Processing MCU file: rm598__09.83.mcusw [BB5,XSR 1.6] size: 28.82 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 280ADC75 CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 0AF0000EB68254407979C12FF0FC388DFCCB4E36 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3B40 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0x8F9A0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 280ADC75 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35483204438175_CERT.rpl" CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: 4431C834027BBA0D18A5ED745CAFA04BA679A74A (RAP Certificate 192 v.1) written. Programming completed in 43.828 s Processing PPM file: rm598__09.83.ppm_mh [BB5,XSR 1.6] size: 6.30 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB Flash programming ... Programming completed in 9.328 s Processing CNT file: rm598__09.83.image_mh_0590404_006 [BB5,XSR 1.6] size: 15.42 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB Flash programming ... Programming completed in 23.781 s Total time for flashing process(boot+erase+write) was 1 min 43.953 s WBR sahil2000ind |
02-10-2011, 08:14 | #11 (permalink) |
Member: 230266 Status: Offline Thanks Meter: 34 | Successfully Unlocked RM-495 (Nokia 5130c-2) 12 hours Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35831803869838-1 Product Code: 0577511 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358318038698381 Version: SIMLOCK SERVER Provider: M-Tel GSM BG , Country: Bulgaria Counter: 2/3, 0/10 CONFIG_DATA: 2840100053285640 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 28401F, DATA=28401F [Bulgaria-M-Tel GSM BG ] SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 #pw+ 090638602808465 +1 # #pw+ 369964672407580 +2 # #pw+ 299224015072076 +3 # #pw+ 182979654279534 +4 # #pw+ 763127388928152 +5 # #pw+ 836131512390257 +6 # #pw+ 005469671231558 +7 # Codes file saved to: C:\mobileEx\3.4\data\SL3\358318038698381_SP_CODES. txt Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Reading Simlock info ... Imei net: 358318038698381 Version: SIMLOCK SERVER Provider: M-Tel GSM BG , Country: Bulgaria Counter: 0/3, 0/10 CONFIG_DATA: 2840100053285640 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=28401F |
03-19-2011, 19:27 | #15 (permalink) |
No Life Poster Join Date: Jun 2006 Location: TUNIS Age: 45
Member: 287132 Status: Offline Sonork: 1236544 Thanks Meter: 96 | i have 5870 xfx with 1.9 , 1salt take 1min and now more 4min!!!! driver installed 10.3 ,plz what s best configuration, i use windows 7 64bit,plz need help and more info about your config and system thx |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
