Old 07-01-2010, 22:46   #1 (permalink)
Member: 1216263
Thanks Meter: 130
Question Successfully Unlocked Nokia 1208, but I have no signal?? Please help!
Hi
I successfully unlocked Nokia 1208 RH-105 v5.06, but I have no signal. My customer said that he brought the phone from China. He wants to use it here in Argentina. Here's my log:
Phone Type: RH-105
SW Version: V 5.06 12-01-08 RH-105 (c) NMP
Imei plain: xxxxx802428624-1
Product Code: 0549935
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: QA
Language Pack:
- not available.
Imei net: xxxxx802428624
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
As you might see, when the sim is inserted, there is no "failed to register" or similar message. And the little antenna at the top left screen appears, but I have no signal!!
Any ideas?
Thank you
edit: I think the reason that I can't have signal, is because this phone is "GSM 900 / 1800", and here in Argentina we use "GSM 850/1900". Could that be the reason?
Old 07-02-2010, 00:17   #2 (permalink)
Member: 69911
Thanks Meter: 69
that's it... that phone uses 900/1800...
Old 07-02-2010, 00:26   #3 (permalink)
Member: 1216263
Thanks Meter: 130
Is there a way to convert from "GSM 900 / 1800" to "GSM 850/1900"?
Thank you!
Old 07-02-2010, 01:52   #4 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Thank you!
Ask Nokia to do it for you in their factory, or buy a new phone what support GSM 850/1900.
No other way,
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
Old 07-02-2010, 04:40   #5 (permalink)
Member: 1216263
Thanks Meter: 130
OK. I thought there were some RPL that I could upload to the phone. But thank you anyway
Old 07-02-2010, 05:19   #6 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
You may try by changing filters used.
Not sure about that but is worth a try.
Br,
Shadab Ahmad
Old 07-02-2010, 08:31   #7 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
hey dude just change filters then ur problem will b solved .... after that write good pm then factory reset
i just tried on 1600b to 1600 ......
Br,
akashub
The Following User Says Thank You to akashub For This Useful Post:
Old 07-02-2010, 08:37   #8 (permalink)
Member: 460280
Thanks Meter: 73
Br,
Shadab Ahmad
Yes this is true, use filters from 1208b.
JOHN Q.
Old 07-02-2010, 13:58   #9 (permalink)
Member: 1216263
Thanks Meter: 130
Thank you all for the tip
The Following User Says Thank You to gasto40 For This Useful Post:
Old 07-02-2010, 15:58   #10 (permalink)
Member: 670138
brother ,first of all dont change any filters,just write good pm and factory settings it happen all the time when you flash the phone even with the same versionand i advise you to use the version 5.23 its good,then if it doesnt work change them....
Old 07-02-2010, 16:30   #11 (permalink)
Member: 1216263
Thanks Meter: 130
By writing good PM and then factory settings I can convert from "GSM 900 / 1800" to "GSM 850/1900"?
Old 07-02-2010, 16:56   #12 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Yes, but you must change Filters too.
Br,
Shadab Ahmad
The Following User Says Thank You to [Shadab_M] For This Useful Post:
Page generated in 0.29583 seconds with 10 queries
