Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 12-16-2009, 16:34   #1 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1601130
succsesfull unlock nokia 2720a-2b with mxkey
Imei net: 01204600*****
Version: SIMLOCK SERVER
Provider: T-Mobile, Country: U.S.A.
Counter: 0/3, 0/10
CONFIG_DATA: 3102000000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.LOCKED (MCC+MNC): 310160
BLOCK 2: 1.LOCKED (MCC+MNC): 310200
BLOCK 3: 1.LOCKED (MCC+MNC): 310210
BLOCK 4: 1.LOCKED (MCC+MNC): 310220
BLOCK 5: 1.LOCKED (MCC+MNC): 310230
BLOCK 6: 1.LOCKED (MCC+MNC): 310240
BLOCK 7: 1.LOCKED (MCC+MNC): 310250
BLOCK 8: 1.LOCKED (MCC+MNC): 310260
BLOCK 9: 1.LOCKED (MCC+MNC): 310270
BLOCK 10: 1.LOCKED (MCC+MNC): 310310
BLOCK 11: 1.LOCKED (MCC+MNC): 310580
BLOCK 12: 1.LOCKED (MCC+MNC): 310660
BLOCK 13: 1.LOCKED (MCC+MNC): 310800
BLOCK 14: 1.LOCKED (MCC+MNC): 310490
PhoneType:RM-519
SwVersion: V 08.20 30-06-09 RM-519 (c) Nokia
MCU file: rm519__08.20.mcusw
Trying to find patch position ...OK
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 009C3B61:3B8ADA60
Area [01000000-0101FFFF] erased in 0.750 s
Area [01220000-0123FFFF] erased in 0.750 s
Area [01440000-0145FFFF] erased in 0.765 s
Area [014C0000-014DFFFF] erased in 0.735 s
Area [01CC0000-01CDFFFF] erased in 0.015 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 1 min 10.515 s
Reading Simlock info ...
Imei net: 01204600024515
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
br.
hanif007
Old 12-16-2009, 19:06   #2 (permalink)
daroas's Avatar
Member: 194078
2720 unlock 100% free??
The Following 3 Users Say Thank You to daroas For This Useful Post:
Old 12-16-2009, 19:26   #3 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
congratulations ............
The Following User Says Thank You to khadim100 For This Useful Post:
Old 12-17-2009, 06:54   #4 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1601130
yes its freeeeeeeeeeeeeeeeeee
here the procedure...
The Following 2 Users Say Thank You to hanif007 For This Useful Post:
Old 12-20-2009, 07:52   #5 (permalink)
POLARBOX_TEAM's Avatar
Member: 1021855
Sonork: BLACKBERRY INSIDE
Angry 2720a convert to 2720 success unlock to mxkey
hello.here the log unlock 2720a
Imei net: 01204600037657
Counter: 0/3, 0/10
PhoneType:RM-519
UEM ID: 00953F79:3B8ADA60
Area [01000000-0101FFFF] erased in 0.906 s
Area [01440000-0145FFFF] erased in 0.719 s
Area [014C0000-014DFFFF] erased in 0.891 s
Area [01CC0000-01CDFFFF] erased in 0.016 s
Programming ...
Completed in 1 min 14.047 s
Counter: 0/3, 0/10
regards
The Following 4 Users Say Thank You to POLARBOX_TEAM For This Useful Post:
Old 01-22-2010, 00:26   #6 (permalink)
nefreyu's Avatar
Member: 538861
Sonork: 100.1578309
is 2720 v8.42 supported with mxkey?
The Following User Says Thank You to nefreyu For This Useful Post:
Old 01-22-2010, 00:38   #7 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Yes, supported. I have done a few
The Following 2 Users Say Thank You to fun For This Useful Post:
Old 01-22-2010, 00:39   #8 (permalink)
connn's Avatar
Member: 1087145
congratulations+thanks
The Following User Says Thank You to connn For This Useful Post:
Old 01-22-2010, 02:00   #9 (permalink)
nefreyu's Avatar
Member: 538861
Sonork: 100.1578309
Thankyou now i will order
Old 01-22-2010, 03:50   #10 (permalink)
azad4u's Avatar
Member: 497374
Sonork: 1587252:AZAD
thanks for ur nice update
The Following User Says Thank You to azad4u For This Useful Post:
Old 01-25-2010, 18:44   #11 (permalink)
angelcelu's Avatar
Member: 558475
please upload file mcu 8.20
The Following User Says Thank You to angelcelu For This Useful Post:
Old 01-26-2010, 05:45   #12 (permalink)
xahin's Avatar
Member: 536012
Sonork: Worlds Is Not Enough 007
thanks for ur nice info
The Following User Says Thank You to xahin For This Useful Post:
Old 01-26-2010, 07:55   #13 (permalink)
adaki_vishal's Avatar
Member: 230121
what abt network is it fully working
The Following User Says Thank You to adaki_vishal For This Useful Post:
Old 01-30-2010, 16:19   #14 (permalink)
Member: 749051
Imei net: 01204600376857
Counter: 0/3, 0/10
PhoneType:RM-519
SwVersion: V 09.55 12-11-09 RM-519 (c) Nokia
MCU file: rm519__09.55.mcusw
Trying to find patch position ...Sorry, no routine found or not supported model !
The Following 3 Users Say Thank You to abdul777 For This Useful Post:
Old 02-01-2010, 06:42   #15 (permalink)
Member: 230121
unlock will be ok have to change the filters for network solution better use 1600 filters
Nokia 2720a-2b RM-520 Unlock curtisbcm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 09-09-2010 02:57
Nokia 2720a-2b flashing problem partapmobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-27-2010 05:59
can i unlock RM-513 Nokia 2330c-2b with ub sr8787 Universalbox 5 02-27-2010 17:39
Nokia 2720a-2b RM-520 BAND CHANGE RPL NEEDED URGENT...!!! Mr.Ultimate Nokia Digital Core Technology 4 ( DCT-4 ) 3 02-05-2010 14:08
Page generated in 0.46904 seconds with 11 queries
