.::: Sucessfully Flashed X-GOLD/Infineon devices(1202,1616,1800, etc) :::. 1616 sucessfully flashed with Mxkey PHP Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r04.100.fls from file rh125_004.100 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 1 min 7.437 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 1 min 5.444 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.091 s Checksum OK (0x1ABE) Processing CUST:hw_f11_rh125_004.10ia.fls from file rh125_004.10ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 1 min 4.773 s Checksum OK (0x5DC5) Processing CUST:hw_f11_rh1250_nai04.10ia.fls from file rh1250_nai04.10ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 12.258 s Checksum OK (0xDE24) Flashing completed in 5 min 13.140 s Phone Type: RH-125 SW Version: V 04.10 26-03-10 RH-125 (c) Nokia Imei plain: 35xxxxxxxxxxxx-x Product Code: 0588620 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35xxxxxxxxxxxx Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 5 min 33.610 s
