05-25-2010, 13:26 | #316 (permalink) |
Freak Poster Join Date: May 2008 Location: LAGOS NIGERIA
Member: 773516 Status: Offline Sonork: 100.1583311 Thanks Meter: 69 | 2220s-RM-590 unlock sucessfully Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001CBC88:3B8ADA60 ASIC type: 11 UEM Imei: 35831203032816 Flash Imei: 35831203032816 MasterCode: 4610030043 RPL saved to "C:\mobileEx\3.4\data\backup\35831203032816_BACK.r pl" Phone Type: RM-590 (Nokia 2220s) SW Version: V 09.75 07-01-10 RM-590 (c) Nokia Imei plain: 35831203032816-2 Imei OTP: 35831203032816 Product Code: 0598932 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: AE Language Pack: - not available. Imei net: 35831203032816 Version: SIMLOCK SERVER Provider: Tesco Mobile, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23410F AFTER UNLOCK Imei net: 35831203032816 Version: SIMLOCK SERVER Provider: Tesco Mobile, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23410F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-590_35831203032816_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35831203032816 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-26-2010, 15:35 | #317 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | nokia 2220 unlock done with mx key Quote:
05-29-2010, 05:40 | #318 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | 1661 unlock done...... Imei net: 35823303859963 Version: SIMLOCK SERVER Provider: Virgin - SPECIAL CODE, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 23430F 2.LOCKED (GID1): 2800 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35823303859963_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35823303859963 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-31-2010, 09:43 | #319 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | Nokia 2320 2b unlock done Quote:
06-03-2010, 14:16 | #320 (permalink) | |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | 1202 contact serice solved Quote:
06-09-2010, 16:23 | #321 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Nokia 1661 restarts with sim after repair simlock Imei net: 35799603639589 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35799603639589_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35799603639589 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to abakwa For This Useful Post: |
06-09-2010, 16:36 | #322 (permalink) |
Insane Poster Join Date: Mar 2003 Location: Mombasa Kenya
Member: 25004 Status: Offline Thanks Meter: 10 | 5300b unlock works like a charm Imei net: 358665010850855 Version: SIMLOCK SERVER VERSION 63 Provider: Rogers AT&T Wireless, Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3027200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 302720, DATA=302720 Backup saved to "BB5_35866501085085_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05.10 29-06-07 RM-147 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\358665010850855_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 38.704 s Restarting phone ... Reading Simlock info ... Imei net: 358665010850855 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
06-09-2010, 16:38 | #323 (permalink) |
Member: 25004 Status: Offline Thanks Meter: 10 | 5300b unlock works like a charm Imei net: 35866xxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Rogers AT&T Wireless, Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3027200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 302720, DATA=302720 Backup saved to "BB5_3586xxxxxxxxxx_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05.10 29-06-07 RM-147 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\358665010850855_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 38.704 s Restarting phone ... Reading Simlock info ... Imei net: 35866xxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF voila!!! |
The Following User Says Thank You to ogudageorge For This Useful Post: |
06-16-2010, 07:45 | #324 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | 2330 unlock done with mx key Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
06-16-2010, 07:45 | #325 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | 1661 unlock done thanks mx key team Quote:
07-05-2010, 10:55 | #326 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 474 | !!1661 Unlocked!! Version Info: MCU SW version: V 03.70 14-04-09 RH-122 (c) Nokia HW version: 1000 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w10_UPP LCD version: WIN:BOHAIv91 NT39121 PPM version: V 03.70 14-04-09 RH-122 (c) Nokia AE ADSP SW version: p V 03.70\n14-04-09\nRH-122\n(c) NMP\nae Product Info: Production serial number: DWE852708 Product code: 0585635 Module code: 0204078 Basic production code: 0568809 Serial Numbers: IMEI warranty: 355221030132388 IMEI plain: 355221030132388 IMEI spare to net: 3A 55 22 01 03 31 32 08 IMEI SV to net: 33 55 22 01 03 31 32 28 F5 Other Info: CS type : GSM/DCS1800 BSI: 4.5 KOhm Imei net: 35522103013238 Version: SIMLOCK SERVER Provider: diAx Mobile, Country: Switzerland Counter: 0/3, 0/10 CONFIG_DATA: 2280200000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 22802F -------------------------------------- Imei net: 35522103013238 Version: SIMLOCK SERVER Provider: diAx Mobile, Country: Switzerland Counter: 0/3, 0/10 CONFIG_DATA: 2280200000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 22802F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35522103013238_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35522103013238 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to azeem781986 For This Useful Post: |
07-09-2010, 14:50 | #327 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | 1661 contact service repaired!! Code: Imei net: 35936403544370 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35936403544370_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35936403544370 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
07-09-2010, 15:16 | #328 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | 1209 sp data corrupted solved thnx to mx-key ! Code: Imei net: 35320203363028 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-105_35320203363028_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35320203363028 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to kmaxmax For This Useful Post: |
07-09-2010, 22:21 | #329 (permalink) |
Freak Poster Join Date: May 2009 Location: Poland
Member: 1031096 Status: Offline Thanks Meter: 77 | Nokia 1661 flash and unlock ok: Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0034B603:DA3BDA66 ASIC type: 11 UEM Imei: 357996036xxxxx RPL saved to "C:\mobileEx\3.4\data\backup\357996036xxxxx_BACK.rpl" Processing file: rh122_005.010 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0034B603:2984DA60 Area [01000000-0100FFFF] erased in 0.891 s Area [01010000-0179FFFF] erased in 1 min 42.440 s Area [017A0000-017EFFFF] erased in 4.266 s Area [01F00000-01FDFFFF] erased in 0.463 s Flash programming ... Programming completed in 19.311 s File Processed in 2 min 15.590 s Processing file: rh1220_nai05.01ea as CNT [DCT4,DCT4 ALGORITHM] size: 176.34 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0034B603:2984DA60 Area [01750000-0178FFFF] erased in 3.587 s Flash programming ... Programming completed in 1.611 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.877 s File Processed in 27.644 s Processing file: rh122_005.01ea as PPM [DCT4,DCT4 ALGORITHM] size: 2.54 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0034B603:2984DA60 Area [01250000-0125FFFF] erased in 0.871 s Area [01260000-0174FFFF] erased in 1 min 6.947 s Flash programming ... Programming completed in 19.785 s File Processed in 1 min 37.749 s Flashing completed in 5 min 1.376 s Phone Type: RH-122 SW Version: V 05.01 23-09-09 RH-122 (c) Nokia Imei plain: 3579960369xxxx-x Product Code: 0586442 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: EA Language Pack: - not available. Imei net: 357996036xxxxx Version: SIMLOCK SERVER Provider: Virgin - SPECIAL CODE, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 23430F 2.LOCKED (GID1): 2800 Total time to process is 5 min 8.764 s Imei net: 357996036xxxxx Version: SIMLOCK SERVER Provider: Virgin - SPECIAL CODE, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 23430F 2.LOCKED (GID1): 2800 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_357996036xxxxx_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 357996036xxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to mobista For This Useful Post: |
07-14-2010, 08:32 | #330 (permalink) |
Insane Poster Join Date: Apr 2008 Location: Inside Your Boxs , Wild Forest
Member: 756960 Status: Offline Thanks Meter: 48 | Imei net: kami_tera Version: SIMLOCK SERVER Provider: Movistar (DCT4), Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140700000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 21407F BLOCK 2: 1.LOCKED (MCC+MNC): 21402F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_kami_tera_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: kami_tera Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN thanks mx key team....... |
The Following User Says Thank You to kami_tera For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
