Old 02-08-2010, 06:24   #1 (permalink)
naheed_gsm's Avatar
Member: 1025487
Thanks Meter: 64
SUPERDONGLE key Repair problem
hi mr. manole
i have nokia 5130 & 5520 there is superdongle key invalid. Then i will try to mx-key update 1.4 verson. first time `Bus check' show imei is 100% ok. 2nd time i try `Bus check' then show imei is 01234566-?. i will must be confused. so plz plz plz update u r mx-key & relesd new verson.........
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 21000207F2A27D56ADCAA39A80AC1FC301649BDC
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: Empty
Original Product code: Empty
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 12345610654321-?
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Old 02-08-2010, 06:27   #2 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
Originally Posted by naheed_gsm View Post
hi mr. manole
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
both are Sl3 so write backup if you have otherwise no solution at the moment.
Old 02-08-2010, 07:13   #3 (permalink)
naheed_gsm's Avatar
Member: 1025487
Thanks Meter: 64
hello brother i understand this way but sl3 show imei don't kill this.
The Following User Says Thank You to naheed_gsm For This Useful Post:
Old 02-08-2010, 11:35   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
hi.
MXKEY not make destroy your imei,if not erased / reset NPC first
some ppl log, no problem when do "BUS CHECK"
so please check in your side,
br,
Old 02-08-2010, 12:10   #5 (permalink)
naheed_gsm's Avatar
Member: 1025487
Thanks Meter: 64
ok brothr i will try this solution but i recived 5220 model. is problem sd invalid than make contact service what i doing now........
can cyclone repair superdongle key repair 5130c? unlock & flash Cyclonebox 3 01-08-2010 19:56
SUPERDONGLE KEY Repaire Procedure ..::AppleLinks::.. Nokia Base Band 5 ( BB-5 ) 16 12-08-2009 15:54
Nokia N85 contact srvice after superdongle key repair wmli Universalbox 7 12-05-2009 14:45
6300 superdongle key repair done unlock & flash MT-BOX 0 12-03-2009 17:46
Page generated in 0.33607 seconds with 10 queries
