Old 11-25-2009, 17:33   #1 (permalink)
SOPORTEDIGITAL's Avatar
Member: 867386
Sonork: 100.1584704
Thanks Meter: 154
SUPERDONGLE_KEY corrupted !
can some body tell me whats mean the follow error !!!!
Sending SecondaryBoot(0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x11C4 bytes) ...Communication problem, please make retry.
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 186.24.16.5
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 11-25-2009, 17:46   #2 (permalink)
Member: 1086393
Thanks Meter: 771
Hello Try again its a server problem- try 2 or 3 times it will be ok if your SD key is not corrupted.
It'll best if you post scan/bus check logs here.
Old 03-26-2010, 08:32   #3 (permalink)
Member: 899842
Thanks Meter: 4
sir
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0B2002025F4F7A5655D8E36E45A555708EBEEDBD
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Original Imei: 35983001495322
Original Product code: 0549247
Bluetooth ID: 001EA3EC4ADB
Phone Type: RM-272 (Nokia 3500c)
SW Version: V 07.21 05-11-08 RM-272 (c) Nokia.
Imei plain: 35983001495322-5
Product Code: 0549248
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359830014953225
Version: SIMLOCK SERVER VERSION 63
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN, DATA=00101F
healps argent
Old 03-26-2010, 08:38   #4 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
in this case
a.press repair Super Dongle
b.than super SD Auth PM
c.than good pm including fields pm1 and pm309
The Following User Says Thank You to rakesh15 For This Useful Post:
Old 03-26-2010, 09:06   #5 (permalink)
raza ahmad's Avatar
Member: 618615
Thanks Meter: 85
plz backup rpl and repair sd after write pm 1;309 all ok
The Following User Says Thank You to raza ahmad For This Useful Post:
Old 03-26-2010, 09:23   #6 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
bro press super sd tab ten write modified pm. not use sx4 server for write pm.
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 04-13-2010, 07:38   #7 (permalink)
Member: 899842
Thanks Meter: 4
sir,
your advice right but no network search all oparator hear sealf test
Phone Type: RM-272
SW version: V 07.21 05-11-08 RM-272 (c) Nokia.
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
20 BACKUP_BATT N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO Y passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
56 SLEEPCLK_FREQ N passed
101 BTEMP N passed
107 BT_SLEEP_CLK N !no signal
108 EXT_DEVICE N passed
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
85 CDSP_TX_IQ N !no signal
74 CDSP_TXC_DATA N !no signal
79 CDSP_RX_PLL_PHASE_LOCK N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
77 CDSP_GSM_TX_POWER N !no signal
plese healpsssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssss
SUPERDONGLE_KEY corrupted !-PLS HELP vistasamir MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 03-27-2010 06:51
SUPERDONGLE_KEY corrupted problem xvirus MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 09-10-2009 23:17
SUPERDONGLE_KEY corrupted !-PLS HELP vistasamir MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 08-22-2009 07:04
6300 watchdog problem, Bad phones ack, probably SUPERDONGLE_KEY corrupted ! swechacnu MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 08-14-2009 05:54
SUPERDONGLE_KEY corrupted az_liton MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 06-24-2009 18:42
Page generated in 0.18298 seconds with 9 queries
