Old 02-16-2010, 08:29   #1 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
SUPERDONGLE_KEY ...error 0x0
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V ICPR71_09w22.9 16-10-09 RM-407 (c) Nokia
ApeCoreSw: 400.21.013
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 16.375 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-407_35292402xxxxx_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...
error 0x0
Updating SIMLOCK...OK
Old 02-16-2010, 08:33   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
e71-3 try this way backup full rpl and pm after backup rest npc and update sd after update sd write rpl then write pm with super sd auth
Old 02-16-2010, 08:34   #3 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
im finish my work and its done. and same problem here... use UFS box not JAF. your problem is solve.
Old 02-16-2010, 08:35   #4 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
same error with n73 too
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 359738005xxxxxxx
Product Code: 0529785
ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133
ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133
Language Pack:
English,02 Uk
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359738005xxxxxx
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Completed in 17.968 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_359738005xxxx_SIMSD.RPL"
error 0x0
Old 02-16-2010, 08:37   #5 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
i already tried to use ufs but get the same error
Old 02-16-2010, 08:38   #6 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
read pm then click super sd then write
Old 02-16-2010, 08:39   #7 (permalink)
Member: 309754
Sonork: 100.1624083
Thanks Meter: 22
1 salect Init Simlock
2 salcet make simlock rpl
3 update splock
4 repair sd
Updating SUPERDONGLE_KEY ...OK
Old 02-16-2010, 08:41   #8 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
ERROR: Missing SD BLOCK or PM corrupted !
Old 02-16-2010, 08:43   #9 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
try to restart your PC.
Old 02-16-2010, 08:46   #10 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Updating SUPERDONGLE_KEY ...error 0x0
press SCAN button and upload logs here
also upload RPL here on forum
thanx
Old 02-16-2010, 09:00   #11 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
Phone Type: RM-407 (Nokia E71)
SW Version: V ICPR71_09w22.9 16-10-09 RM-407 (c) Nokia
Imei plain: 35292402720xxx-7
Product Code: 0572960
ApeVariant: 400.21.013, ApeProd: )400.21.013 22-10-2009 RM-346 (c)Nokia
Language Pack:
- not available.
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 35292402720xxxx
Counter: 0/3, 0/10
The Following User Says Thank You to ghost_team For This Useful Post:
Old 02-16-2010, 09:07   #12 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
ok come on msn will solve in few mins
Old 02-16-2010, 09:36   #13 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
for all of u . i will only sort out ur problems through team viewer . will not teach u how to repair the RPL to sort out such problems . thanx to understand
Old 02-16-2010, 11:06   #14 (permalink)
Member: 103578
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Try with mobileEx 3.3 (rev1.4)
Old 02-16-2010, 14:21   #15 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
Smile
Completed in 7.563 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-407_3529240xxxxx137_SIMSD.RPL"
it was server problem
SUPERDONGLE_KEY ...error 0x0 solution here hasnain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 02-17-2010 20:38
SUPERDONGLE_KEY ...error 0x0 hasnain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 02-16-2010 14:13
SUPERDONGLE_KEY corrupted problem xvirus MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 09-10-2009 23:17
SUPERDONGLE_KEY corrupted az_liton MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 06-24-2009 18:42
Page generated in 0.27540 seconds with 11 queries
