06-04-2013, 08:57 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: UG Age: 31
Member: 1448098 Status: Offline Thanks Meter: 9 | SUPERDONGLE_KEY invalid! NOKIA ASHA 306..HELP Using device: USB ROM Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL) Processing file: rm768__05.93.mcusw Downloading item CODE:rm768__05.93.mcusw_ebl_psi.fls, num block: 4, size: 29.02 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.344 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.360 s Erasing area 0x40060000-0x4011FFFE ...OK Programming completed in 1.172 s Erasing area 0x40120000-0x41D23FFE ...OK Programming completed in 36.859 s Checksum verified (0x08A0) Processing file: rm768__05.93.ppm_l Downloading item CUSTackage_l.ppm_ebl_psi.fls, num block: 1, size: 5.78 MB Erasing area 0x41D40000-0x42306DAA ...OK Programming completed in 8.187 s Checksum verified (0x0C3F) Processing file: rm768__05.93.image_l_059L9F8 Downloading item CUSTackage_l_059L9F8.image.fls, num block: 1, size: 13 MB Erasing area 0x42540000-0x43EDFFFE ...OK Programming completed in 17.969 s Checksum verified (0x7E35) Total time for flashing process(boot+erase+write) was 3 min 34.343 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 351954055458106 Verifying communication to device OK. Phone type: RM-768 (Nokia 306) SW version: V 05.93 09-11-12 RM-768 (c) Nokia Imei plain: 35195*********** Product code: 059M175 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 115B6002004020, ver: RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-768_351954055458106_04_06_13_102819_SIM.RPL" SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35195405****** Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN SUPER DONGLE KEY INVALID HELPPPPPPP..... |
06-04-2013, 09:24 | #3 (permalink) | |
Member: 1448098 Status: Offline Thanks Meter: 9 | Super dongle key invalid Quote:
NEED HELP 4 DAT...... Last edited by latif12; 06-04-2013 at 09:29. | |
06-05-2013, 08:23 | #8 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Tick Factory Reset All on After Flash Process, Try Flash again with disable Safe Erase, Now Check & post Full Logs if not solve. BR, ZUBER |
