05-21-2009, 15:13 | #3 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Ampah, East Barito -Indonesia Age: 44
Member: 238204 Status: Offline Thanks Meter: 56 | Hi bro...., SX4 is OK !..... Check your phone..., or try using SX4 bypass. |
The Following 3 Users Say Thank You to m_amien For This Useful Post: |
05-23-2009, 16:29 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: ((EGYPT)) walid badr Age: 44
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | don't work with me log Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 217.139.56.166 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! br |
05-24-2009, 15:39 | #8 (permalink) | |
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | Quote:
realy it's worked well not only me take a look http://forum.gsmhosting.com/vbb/showthread.php?t=757030 br | |
The Following User Says Thank You to mr.6630 For This Useful Post: |
05-24-2009, 18:42 | #9 (permalink) |
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | another phone 3110c worked well put sx4 still same Version Info: MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia. HW version: 4001 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. MEA BT MCM version: 6cc-P9.1 Retu version: 32 Tahvo version: 53 Serial Numbers: IMEI plain: 3530xxxxxxxxxxxx IMEI spare to net: 3A 35 80 06 02 75 18 03 IMEI SV to net: 33 35 80 06 02 75 18 23 F5 Other Info: Model : Nokia 3110c (Classic Phone) Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 217.139.238.222 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 217.139.238.222 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 217.139.238.222 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 217.139.238.222 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! fix it plz br |
05-25-2009, 05:08 | #11 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Problem in pm for super dongle key error.... make npc erase write full pm from other phone including its 308 and then perform repair and unlock now make sx4 should work |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
05-25-2009, 16:43 | #12 (permalink) | |
but till now i tested 5 phone worked very well but when try to make sx4 to test it i have same problem i think not only me have this problem many post's ask about this problem br | |
05-27-2009, 12:42 | #15 (permalink) | |
Junior Member Join Date: Jul 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 806993 Status: Offline Sonork: yudi_lk Thanks Meter: 6 | Quote:
i do have the same problem too.... its realy suck,,,,,, | |
Big problem in MX-KEY 3.3 v1.7 | rajmobile123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 25 | 04-08-2010 07:19 |
Big Problem in Mx-Key | nomi_42us | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-24-2010 10:15 |
i have problem in mx key when i flash | israrbjr | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-27-2010 13:45 |
problem in mx-key error in flash | FEATURE GSM™ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-30-2009 09:23 |
Sx4 auth done by mx-key | palash_c6 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 06-06-2009 09:05 |
