Old 02-06-2010, 10:14   #1 (permalink)
obioha's Avatar
Member: 121356
Thanks Meter: 73
thank you manole, 3110c security test passed
just did security used your new solution,
We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...)
Now all SD repair should work well.
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here
and it was perfect. see the log on 3110c
3110c - Security Test Failed ## (ANSWERED) jesuraja MXKEY Nokia Flasher and Unlocker (by Alim Hape) 29 10-31-2011 16:00
3110c - Security Test Failed. Help! [Shadab_M] MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-30-2010 10:43
SECURITY Test passed with bad NPC ? JAVA Good Cyclonebox 6 03-24-2010 11:24
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
mx key team 3110c security test failed sanjayvikas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-31-2010 23:42
Page generated in 0.21817 seconds with 8 queries
