02-07-2010, 20:33 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: shimoga Age: 40
Member: 781262 Status: Offline Thanks Meter: 90 | is ther any procedure write back rpl |
02-07-2010, 20:39 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
you have full rpl? imei is ok? | |
02-08-2010, 07:02 | #5 (permalink) | ||
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
It's 1-st thing that you can know downgraded phone... Quote:
1. Erase phone again. 2. Flash it with latest version ( must be same or highner that original one ). Phone must be power on local / test mode with empty IMEI ... 3. Write now good full PM ( can search here: http://forum.gsmhosting.com/vbb/showthread.php?t=711296 ). 4. Write original PM field 120 and 308. 5. Write back stored IMEI certificates. All must be fine... ( if you have NPC and 308 correct saved )... If no !!! then procedure will fail in point 4. and 5. and must be maded like follow: ... in case of wrong SIM-lock data: 4. write NPC data back. 5. Use procedure from: http://forum.gsmhosting.com/vbb/show...36&postcount=1 That's all ... | ||
can't write back rpl | alvis168 | Universalbox | 13 | 10-21-2008 17:17 |
is ther any way to change imei of SE p910i | sachinvij1 | Sony Ericsson | 1 | 12-25-2005 04:53 |
Is ther any problem with | gedan | TST Dongle | 1 | 08-20-2005 20:35 |
Is ther any solution for : Phone failure ??? | sifasli | x1x to x45/x50 | 1 | 07-18-2001 12:54 |
