Old 06-17-2011, 12:07   #1 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Tips installing MXKey 3.5 rev1.1 and UFS HWK Without error.(ANWERED)
I've read in this forum so many people complain about their UFS not detected after installing new MXKey soft v3.5 rev1.1, strange error message appear when opening MXKey soft, and soon.
So here i try to share my experience installing MXBox, UFS, and MXKey without problem.
I installed MXKey v3.5 rev1.1 on 2 PC. On 1st PC i use HTIBox and HWKBox, and in the other PC i use UFS Tornado and MXKey dongle.
Here is the step installing.
1. If you haven't, install HWK Suite latest version (2.2.0.0) and update UFS Driver.
2. Uninstall previous installed MXKey software.
3. Go to c:\MobileEx and delete folder. (Make backup for RPL and PM file located in c:\MobileEx\3.5\data\backup)
4. Open Regedit, go to HKLM\software\MobileEx, and delete the registry key
5. Go to HKCU\software\MobileEx, and delete the registry key
6. Restart the PC
7. Install MXKey v3.5 rev.1.1
8. (For HTI User) When Ask for driver, point it to c:\MobileEx\3.5\Data\Drivers\HTI
9. Update HTI Firmware to version 00.17
10. When Firmware update complete HTI will ask for new driver, point it to c:\MobileEx\3.5\Data\Drivers\HTI
11. Run Partial Update for Nokia Service Tool and Blackberry Tool
12. Done, Now MXKey ready to use.
Here is some screenshoot:
USING HTI BOX:
Using USF with HTI Box as Smartcard Reader:
Using MXKey Dongle:
In my opinion, so far this is the best update from MXKey Team :
Hope this tip can help you people to solve your problem. Good Luck.)
The Following 19 Users Say Thank You to shybet For This Useful Post:
Old 06-17-2011, 12:13   #2 (permalink)
Member: 1598381
Sonork: 1595992
Thanks Meter: 20
nice sharing this is a good solution for me may mxkey is alway error tnx for the tips...
Old 06-17-2011, 12:24   #3 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,501
nice sharing info ...........................
Old 06-17-2011, 12:39   #4 (permalink)
Member: 1559197
Sonork: 100.1604096
Thanks Meter: 425
my one is runing without any trouble.................i think i am lucky in this case
Old 06-17-2011, 14:47   #5 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 306
Old 06-17-2011, 15:09   #6 (permalink)
Member: 1194626
Thanks Meter: 34
i have try that way bro....but it's not work........
but since use windows 7.........it's work 100%......no need trik anymore.....
Old 06-17-2011, 15:36   #7 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
not working bro .................
Old 06-17-2011, 15:42   #8 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
not solved.........................................
Old 06-17-2011, 16:09   #9 (permalink)
Member: 190123
Thanks Meter: 8
Hi, good solution but please send to share ufs driver 3.8.14.0 version.
Old 06-17-2011, 16:11   #10 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Can you give me the detail about your problem? Maybe we can try to get a solution for it.
Old 06-17-2011, 16:31   #11 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
in win7 may be its working fine but in XP its not working
check ur oprating system is win7 so its work it without any trick or chenges
give any screenshot with xp
Old 06-17-2011, 16:34   #12 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
I TRY THIS TIP'S BUT CAN'T SUCESS
Old 06-17-2011, 16:44   #13 (permalink)
Member: 1524461
Thanks Meter: 26
i have no problem
this is created by our own mistake .
fisrt install 3.5.1.1 mxkey setup .
then update the box property
then update minor updates also.
blakberry
nokia
cdma now available.
then un install ufs old setup & driver.
install 2.2.00 support suite setup
update box properly.
now install main setup 2.2.00
if you have 2 ufs box
then connect both box to usb before installing main setup
box should be connected firt both box then install main set up.
and now put your mxkey dongle in slow usb
and mx box in fast usb
and do usb flashing from another fast usb.
now you mxkey will support box hti box and ufs box. better then before.
Old 06-17-2011, 16:46   #14 (permalink)
Member: 1534157
Thanks Meter: 23
how to driver 2011 updet
Old 06-17-2011, 17:04   #15 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
FYI, i'm using Win XP brother.
The Following User Says Thank You to shybet For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.32025 seconds with 9 queries
