04-03-2010, 15:20 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | TX line remains low???? I am always getting this error....but if I use HWK ...there is no problem and I use the same cable.... So what is the problem in Mxkey??? the log.. Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 00 EE EE EE TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
04-03-2010, 15:33 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | becoz u cant change upper dct4 and bb5.when ur cell phone come dct4 select dct4 and when bb5 upper select bb5 then bus check |
The Following User Says Thank You to Ramzan khan For This Useful Post: |
04-04-2010, 07:01 | #3 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | brother ur jaf or potato box is damage i m also face this problem i m buy a new jaf and problem is solve |
The Following User Says Thank You to tarunvishal For This Useful Post: |
04-05-2010, 08:55 | #4 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | For 1200.. Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 00 DD DD DD TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. did I want to change any settings....... |
nhm-5 phone not put tx line low for bootstrap begin | bhogpurmail | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-13-2006 02:23 |
unable to set the phone in dct4 flash mode - tx line remain high | Egypt Unlocker | Federal One | 11 | 03-21-2004 10:41 |
After start TX signal remains low | pipasbe | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 01-19-2004 23:19 |
8310 .. After MBUS signals TX remain low | Neo777 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-27-2003 17:16 |
Tx Remains Low - Dct4 Flasher | MadPhone | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 06-13-2002 15:00 |
